Blower not working on 1987 intertherm
Hi, i was just wandering if you would know a little about older model intertherm a/c units for trailer
    Sergeant:
  • 288 Answers
Well. you need to ask a specific question. As a rule, motors are motors , no matter what they are on.
Posted on Dec 19, 2007
I HAVE A MODEL UFG-101AG-4 SERIAL # 800H2 INTERTHERM FORCED AIR FURNACE FOR MOBILE HOME OR TRAVEL TRAILER THAT I DONT KNOW WHATS WRONG WITH IT?
OK. Let me answer you, even if honestly I don't have any idea about an INTERTHERM FORCED AIR FURNACE. To get any answer, to a problem, you should describe your problem. Just telling that you don't know what's wrong with it is simply no enough information, even for a star expert in your INTERTHERM FORCED AIR FURNACE.
Jun 25, 2015 | Intertherm Heating & Cooling
SERIAL # IK0487-01713
I googled: Intertherm Air Conditioners There are a number or articals that may help you find what you need. One referance to a youtube "review" Hope this helps. I was going mention "how do you know it's a bad blower motor? But depending on age and use anything is possible. Usually the motor has a model number on it. That would be the safest way to find an exact replacement.
May 12, 2015 | Intertherm Heating & Cooling
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
Nov 25, 2014 | Intertherm Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
I NEED WIRING DIAGRAM FOR A INTERTHERM ELETRIC FURNACE
Web page or the unit door covers , Intertherm are mostly added to trailer homes and check out a trailer home supply house.
Sep 03, 2008 | Intertherm Heating & Cooling
Self contained intertherm ac unit
make sure the unit is level or even off a little to the drain side. I have seen this cause this problem several times.
Aug 07, 2008 | Intertherm P3RC-030K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
