How do I remove the heads from a canon pixma 4500 and how do I unclog them
Inky
  • 691 Answers
SOURCE: Removing the print head
John.
Best solution is to clean the head with it in place. My experience says that if you remove the head, you may as well bin the machine as you can't clean it out of the machine any better than you can with it in-situ.
Send me your email address and I will forward you info on in-situ cleaning that I found works very well. Bear in mind there is also a technical issue with the RX and CX series that causes a blockage in pump drain pipes.
Inky - gamesreplys@yahoo.co.uk
Posted on Jun 14, 2008
SOURCE: Newly installed Canon Pixma 4500
HI
I phoned Canon who told me to return the machine from whence it came!!
Posted on Sep 10, 2008
SOURCE: canon pixma 4500
HI
FIRST YOU HAVE TO MAKE SURE YOU HAVE PURCHASED THE CORRECT WHIT PRINTABLE DISKS.
YOUR PRINTER WOULD HAVE CAME WITH THE NECESSARY SFTWARE CALLED CD PRINT.
OPEN THE PROGRAM AND FOLLOW THE INSTRUCTIONS TO CREATE THE IMMAGE ON THE CD/DVD.
YOU WILL BE WORKING WITH AN IMAGE OF A BLANK WHITE DISK, AND WHAT EVER YOU DO THERE WILL BE PRINTED ON YOUR REAL DISK.
YOUR CANNON PRINTER WILL HAVE AN OPENING IN FRONT WHERE YOU WILL HAVE TO INSERT THE DISK WITH THE PROVIDED TRAY ( A BLACK RECTANGLE WHICH THE CD/DVD WILL FIT ON).
FOLLOW THE INSTRUCTIONS ON THE PC AND YOU CANNOT GO WRONG
Posted on Jan 14, 2009
  • 125 Answers
SOURCE: canon pixma pm500, error code 5200. inocrrect
Issue: ERROR LCD: Error Code 5200
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. Issue: ERROR LCD: Error Code 5200
    Solution: The MP500 may require repair
    Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.Find a Service Location
    If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
    • Obtain Support by Email
    • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. Eastern Time, excluding holidays).
Posted on Aug 25, 2009
ioktay
  • 493 Answers
SOURCE: flasshing five times a orange leds canon pixma 4500
If the LED is blinking 5 times it means ASF (cam) sensor error [5700].
To clear memory, you must reset it.
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
Or,
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Hope this helps.
Posted on Mar 25, 2010
Canon printer banding
On your computer, run the Canon printer software, to run a few "print-head-cleaning" cycles, to unclog any blocked ink-jets.
Jun 07, 2011 | Canon PIXMA MX870 Wireless Office...
Tip
How to unclog a clogged print head on the Canon...
Using a cotton swap dip into some plain water and then drop a few drops of water onto the outlet of the ink cartridge [you will have to remove the ink cartridge and turn it upside down].
Also while the ink cartridge is still removed, drop a few drops of water onto the inlet orifice into which the ink goes. The orifice of the ink cartridge sits right on top of the inlet to the print head when the ink cartridge is fully installed.
After putting the water drops onto the ink cartridge and onto the inlet orifice of the print head, I did the 'clean' procedure as listed in the "Canon PIXMA iP4000 Properties" of the program on my PC. Then I did the deep clean procedure. After that I printed the print pattern and found that this technique worked quite well -- since before I had tried isopropyl alcohol which didn't work to unclogged these print heads.
When I had the blue print head get clogged [on my Canon iP4000 Pixma printer] and I tried this method. It worked immediately.
I hope it works for you too.
God be with you!
engineer550.
on Jun 16, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My canon PIXMA iP 4000 does'nt write out the colours, only black.
Use the Canon software to check the ink-levels in the COLOUR cartridge. If empty, replace it.
Use the Canon software to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are not spraying ink onto the paper.
Feb 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip 4500 error code 6502
Hi,it needs new print head. The print head is not functioning right. I have the same problem, the funny thing is, a new printer cheaper than the print head and a set of ink cartridges .
Hope it helps..
Nov 06, 2010 | Canon Pixma iP4500 InkJet Printer
I am getting error code B200 on my Canon Pixma MP 620 printer
B200 IS BAD PRINTHEAD. i TRIED TO CLEAN CLOGS BUT IN THE END THE FIX WILL BE TO (REPLACE PRINTHEAD) IF UNCLOGGING PRINTHEAD OF DRY INK DOES NOT WORK. YOU CAN UNCLOG BY USING A PRINTHEAD CLEAMING KIT, BUT IF THIS DOES NOT WORK REPLACE HEAD. EBAY WAS CHEAP FOR ME 25 BUCKS PRINTER IS WORKING AGAIN.
Aug 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Cannot get the magenta ink tank to flow in a Cannon Pixma 4500
Yes, you can take the printing head out  and soak it up in hot water. You can even blow some air on it, this will dislodge even the nastiest dried ink gunk. If even after that the head doesn't work then it's dead - buy a new printer.
Jul 11, 2010 | Canon Office Equipment & Supplies
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
My canon pixma ip1980, does not work the power ON, the cartridges were fine( they are new). please help me.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the print head?
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
35 people viewed this question
k24674
jasbo
jasbo
