I have a problem of motherboard Motherboard has power but cant come display. My friend suggest me in the motherboard jumper move it but i cant know which jumper to remove?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
Jumper is a on cornor side of motherboard and is used to reset bios.....
trying to move jumper may not solve your problem .....
if u hear a tone continuesly then it will be ur ram problem..check your ram and try to fit it properly.
if there is no tone then it will be your display adapter problem..check your monitor cable..whether is properly connected with your cpu...if u have discrete graphic solution i.e. u have a graphic card on motherboard then check it if properly fitted..
if this will solve ur problem then ok..
otherwise u have to replace ur mother board..
Posted on Sep 12, 2009
Have a celeron motherboard will power up but no beep or video??\r\nit has a video on motherboard
without a beep its hard to dignose. try clearning the bios info/ remove the cmos battery (looks like a giant watch battery) also there is a jumper next to the batter to reset it. use that jumper by moving the jumper pin over one. if its in clear mode (the jumper) then it wont start. let me know if this helps
Mar 19, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I dont know where power sw goes
It is normally onto a jumper labelled sw - You dont mention the motherboard type, or if you have the instructions. I would suggest looking very carefully on the printing on the board near a bank of upright pins for "sw". It does not matter which way round you put the switch connector.
If you still cant find it, google foe the instructions for your MB
Good Luck
Jan 17, 2010 | EliteGroup P4M900T-M (V1.0) Motherboard
No display and no beep sound, CPU fan working
Hmmm, I have seen a few people reporting this problem with this motherboard... seems to me that it might be a bug in the bios. Well, I had exactly the same problem. It did not even give a beep sound when the memory was completely removed. I was convinced that the motherboard was faulty. Then I thought of trying the following that helped:
On the board the JCMOS1 has 3 pins and pins 1 and 2 are closed in normal operation. Moving the jumper to pins 3 and 4 puts the motherboard in clear CMOS memory mode. So this is what I tried; I move the jumper to pins 3 and 4, pressed power a few times (although I don't think that is necessary), and after about 30 seconds I moved the jumper back to pins 1 and 2. Then when I pressed power the motherboard FINALLY emitted a beep and started up. On first start up I got a message, something to the effect of "CMOS checksum error", but I was then able to go into the bios reset defaults. I then saved and went out and my motherboard has been working fine since then. Hope this helps someone who has a similar issue.
Dec 30, 2009 | EliteGroup P4M800-M7 Motherboard
Ms 6787 no signal input
since you said you do not know anything anything about the jumpers and stuff, probably i suggest you take it to a nearest computer specialist to do it right for you. one thing you have to check up when installing a new motherboard is you power supply, does it have more or less power output? is the local disc or hard drive connected correctly? if you have no idea on all of this then there is a need to have a specialist to do it right for you becauase if not, there would be nothing for you computer to display.
looking forward to hear from you.
thanks,
wonder
Sep 22, 2009 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Msi pm8m3-vh motherboard need to reset bios as comp will not start up
On almost every motherboard, there is a small jumper setting (3 prongs) with a *small yellow* jumper connecting two of the prongs. It is generally near the "chipset" heatsink, nearby the ATA/SATA cable connectors for the Hard Drive(s). Yours may be near the "bottom" of the RAM slots.
If you turn off the computer, turn off the power, unplug the computer, and move the small yellow (sometimes white, but almost always yellow) switch from the two jumpers it's on to connect the middle to the opposite one.
If the jumper is on the left two, move it to the right two. This will include the middle jumper prong.
Leave it that way for 15-30 seconds, and you should reset your BIOS settings.
If that doesnt work, unplug everything and pull the small, quarter sized battery out of the motherboard (directly next to the ATA connectors. (It looks like a large watch battery. You will need a tweezer or small plastic wedge of some sort to move the battery holder out of the way to get it out. It's easier than it sounds, trust me.
If neither of those work...I'd suggest a new motherboard, because both of those methods are supposed to reset the BIOS. Hope it helps!
Sep 15, 2009 | MSI PM8M-V Motherboard
Jumper settings
GO TO MOTHERBOARD MANIFACTURE WEB SITE.
WWW.MOTHERBOARD.ORG
MOTHERBOARD DOWNLOAD DRIVERS
MOTHERBOARD UPDATES
WWW.CORIMAGE.COM
CANDYMANGANDY
Jan 26, 2009 | Cornerstone CHAINTECH 7AJA Socket A ATX...
Need to clear or reset password on a matsonic mb w/win.2000and
you can find the jumper near to the battery on motherboard. it will normally opened, short it.
Jan 20, 2009 | Matsonic MS9158E+ Motherboard
Problem with GA 8LD533
There are a few easy fixes for this, first,
Clear the CMOS (Unplug the power cord, remove the battery, and (if it's an option) move the jumper J1 (it has three pins, the jumper covers two, move it to cover the other one), unplug everything external from the motherboard apart from the PSU and power switch and speaker, replace battery, powercord, and jp1, power up - what happens?
Nov 19, 2007 | Gigabyte GA-8LD533(-P) microATX...
Motherboard or cpu.
reseat the proccesor, check that hard drives have proper jumper settings and the memory stick and cmos battery are seated proper.
let me know
Nov 11, 2007 | Intel Motherboard
T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
May 05, 2007 | E-Machines T2893 PC Desktop
Computers & Internet Logo
David Payne
David Payne
