Question about Freezers
I have a refridgerator model 106.56664500 and it has stopped making ice. Can u help..
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Sep 12, 2009
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Leak from freezer into refridgerator, near the back.
You did not mention what Model and Make it is. That could change a fix.
Just a generic fix, assuming the unit its not too new, the first thing you want to do is turn the water off that is feeding your ice maker. Behind the refer on the wall. Be careful to not kink the water pipe pulling out and putting back the refer during your repair.
If stopping the leak into the refer was accomplished by turning off the water, now your confronted with how old is the refer and is it worth digging around and finding the actual leak. If the leak is in the wall of the refer (not the house wall), basically, just forget it, live with it and buy some ice trays. If you want the ice and it is really old, you may want to take this opportunity to replace the unit.
This would be my first assessment, not knowing age, make and model number. Sorry, wish I could be more helpful.
kindly,
Jim
Jan 16, 2014 | Kenmore Freezers
Pleaaasse help my refridgerator has a side freezer and my freezer gos in n out sometimes it works but when i buy frozen food it seems to stop working it has ice build up and makes loud noises how can i fix...
Hello
Defrost the refrigetator, by open its door for at least 4 hours, and try. If it does not help you, the compressor is faulty, and it will be best fro you to buy a new one, rather than repair this, as it will cost more. OK.
Jan 30, 2012 | Freezers
My daewoo FRSU20DCB has appeared to stop making ice and the top shelf of the freezer and refridgerator are warm? the plumbing to the unit is still working ie we get water but it does not appear to be going...
i have the same problem and have tried to contact daewoo on a number of occasions but only to be passed onto an engineer who wants to charge me min two hundred pounds
Mar 08, 2011 | Daewoo Freezers
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Ice maker not making ice
either the thermostat is bad or the heater isnt working. You could take the icemaker out and connect leads to the heater to see if it warms up or use an ohm meter to test the heater and thermostat. Also take the cover off and see if the cog wheel on the motor is broken.
Apr 29, 2009 | Kenmore Freezers
Freezers Logo
100 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
