Question about Motorola Mobility RAZR V3
Inside and outside screens are blank..
Can still place/receive calls.. just cannot see who is calling or if I am dialing correct number..
  • ram007 Dec 12, 2007
    I have a problem with my Razr.Its been working well for past 1.7 years but just from last week,I dont have display but I can make calls and receive calls.
    thanks,
    Ram
  • Mutantboy1 Dec 14, 2007
    I'm not sure if mine is a V3, but the inside and outside screen just went blank. Is there any solution? I've had it for over a year.
My V3 doesn't work either, the screen randomly turns on occasionally but try taking out the batery and the sim card and they inserting it back in. If this doesn't work i suggest taking the phone back to the place where you brought it. Hope this helps!
Posted on Dec 19, 2007
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
Error message
FDN = Foreign Dial number ( restricted ), so go to call settings and call barring settings and remove restriction,
Jun 23, 2012 | Cell Phones
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
The touch-screen of my phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the lasr dialed or received. Even the accept / reject...
The touch-screen of my china phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the last dialed or received.
Jun 29, 2010 | HTC Touch Diamond Smartphone
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Jun 14, 2010 | Samsung SGH-t219 Cellular Phone
The inside screen doesn't work
change the flat of lcd if it dose not work change the lcd
Nov 24, 2009 | Nokia 6085 Cellular Phone
Panasonic kx-t7030 FWD/DND button
Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
Carl
Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
LG 3300 Screen gone blank
You will need to take the phone to a mobile service center and have them check your lcd and flexcable
Mar 12, 2009 | Cell Phones
Blank screen
well the inside screen is blank but the outside screen isn't icant text or see menus i can stilll dial the numbers just cant see them on the screen
Apr 17, 2008 | Cell Phones
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
