I bought a used line 6 flextone II xl and need a manual
I bought a used line 6 flextone 2 xl and it did not come with a manual.Can I download one on the web? Im having problems programing effects because i dont know what im doing If I cant get a manual can you explain to me how to program my amp
Thanks so much
John
    President:
  • 1,126 Answers
Perhaps one of these .pdf files will suite your needs?
http://line6.com/support/manuals/
Posted on Sep 16, 2009
Line 6 flextone 2 tuner collaboration
ask the same question on "You Tube Broadcast". pretty much every answer u need for line 6 is right there. and w/ a video. someone turned me on to that a few mos. back. wow save me so much time. crazy. good luck!
Sep 17, 2014 | Music
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
The parameters shift up and down while playing
if you're using a pedal. the cat 6 wire that connects the pedal to the amp. can be coming out of the "phone jacks" that line 6 uses, all it takes is for that wire to stretch and if one line breaks . it changes the protocol. sounds like yours is intermittent. put new connectors on each end (after checking continuity),
Sep 03, 2013 | Line 6 Flextone III Plus Guitar Amplifier
I need a manual for a marshall mg15hfx guitar amplifier
I got mine here... http://www.marshallamps.com/downloads/files/MG4%20microstack%20hbk_ENG.pdf great amp, I bought a used one and it is now my main amp-over my Blue Voodoo 1/2 stack and Line 6 Spuder II!!!
Apr 07, 2012 | Music
With my flextone III on start up all the lights come on and no sound. I've tried the factory reset precedures and software upgrade, not the line 6 monkey program, but the midi in and out shows no...
If it has 2 fuses, the second one might be blown. Try replacing the fuses, if its not that then there is a problem with the amp and you will probably need to take it for repairs.
Jul 01, 2011 | Line 6 New Line6 Flextone Iii Xl Amp
The Master Volume control on my Line 6 Flextone II Head is scratchy-noisy when I turn up the volume. I am looking for a replacement, but, Line 6 does not have it on their replacement parts site. The phone...
First try spraying a bit of CRC226 (aaaaaa9make sure it is 226 as there are other products with similar numbers there)available at Home Depot in the electrical dept. into the control where the leads go into it. You may need to bend the plastic spout of the spray can at 90 degrees near the end to get it to go up into the control. This has a high probability to solve your problem.
Getting replacement controls that exactly fit are a major headache from anyplace than the original manufacturer.
Aug 27, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Plugged my fbv Shortboard into my Line 6 Flextone iii and all the lights went red with no lcd read out.
Try plugging it in and then turning on your flextone, or vice/versa. If not than post it on the line 6 website, they have techs look at those problems all the time.
May 20, 2010 | Music
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
I have a Line 6 Flextone III XL. I plugged in my guitar and the sound cuts in and out. It fades in and out. I checked the cable and try using another cable, samething. If I play with the cable by moving...
If the sound "fades" in and out that implies a SLOW change in volume.
If that is what you have, it is likely that there is a problem with the power input or power supply as these are the only thing that would have a time constant to react SLOWLY. Fortunately, this area is one of the easier ones to find and fix.
Dec 07, 2009 | Line 6 Music
597 people viewed this question
 Grubhead
Grubhead
