Question about Refrigerators
Cant find a suitable service centre for the repair of the refrige
My fridge is working and is in a good condition but there is a slight problem with the gasket and the door......so could anybody help?i live in Mumbai and i need an authorised service centre technician to come and have a look at it.
  • 4,070 Answers
Maybe this is your proablem and you can fix it yourself.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Sep 12, 2009
Husband blew out the freon "container" of our Whirlpool 4.4 c.f. refrige - what "contains" the freon? I'm trying to prevent him from going out & buying a new fridge if we can just...
Sorry to read about your problem, I hope this helps you out.
No you cant fix it, it takes special equipment to replace the freon...Please call a service company to make the repairs and do not have you husband touch the system. or you may have to buy a new unit. 2nd you need a EPA federal lic, to work with freon....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Refrigerators
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
We have a Kenmore 20 frostless side by side refrig. It was in the home we recently purchased. When I open the refrig side the door makes a thumping sound at about 3/4 of the way to fully open. It feels...
there is a door cam on the bottom of the door,you have to take the door off to repair it,it's pretty easy to do,if you send model number i could have looked it up for you and gave part number,model number will be inside fridge side up near ceiling or down near the bottom hindge,you will need this to order your part,good luck with door,if the light is staying on take bulb out so the fridge doesn't heat up
Nov 21, 2009 | Kenmore Refrigerators
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Samsung RS2630SH
in the power surge first the LVT orTransformer will blowoff so first you have to change the Transfomer
Sep 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Roper Fridge problem
you tried ither outlets andthe refrig wouldnt work??? or the surronding outlets didnt work??? if the refrig "POPPED" the outlet and surronding outlets sounds like you have a direct short within the refrig somewhere. no real quick fix for sucha thing other thtn physically checking all components looking for where hte trouble occourred
Mar 20, 2008 | Refrigerators
Ref: Servicing of Daewoo Refrigerator
I am in search of Daewoo Refrigerator Service Centre telephone and address in Mumbai, preferably in Dadar. If you know, please mail at mbsabnisandco@hotmail.com or Ph. 22653791
From,
Mrs. Padma D. Mulay.
Oct 14, 2007 | Daewoo FR-147RV
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
