Question about Intel Motherboard
My d101ggc motherboard's sound card is not working properly mic is working but audio out is not working in vol control rear speaker icon is disable pls any body help
  • 74 Answers
Try to reinstall the driver and updatre version of your sound card
Posted on Sep 12, 2009
I am installed my pc (D101GGC) sound driver but i cant hear any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 18, 2011 | Intel D101GGC Motherboard
Microsoft Bus Driver Intel d101ggc motherboard sound problem
also
hope this helps
May 03, 2011 | Intel D101GGC Motherboard
The operation system in my computer is Windows xp professional service pack3. I have intel D101GGC motherboard. I installed the audio driver AUD_XP_5.10.0.6201_PV.exe to my computer but it was not...
you might not have a sound card installed on your computer or it might not be recognised due to a dirty socket if there is a sound card you could remove it from the socket and clean it if your computer came with a motherboard disc the sound drivers could be on it
also
hope this helps
you might have to get another sound card or a portable usb sound card if you dont have a sound card installed
hope this helps
Apr 13, 2011 | Intel D101GGC Motherboard
My lan card drivers are not working. I have Intel D101GGC Motherboard. Please help in that problem. As soon as possible..
1st you check the Lan card driver is properly Installed.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Network Adapter
  • See the Lan Card Driver.if it is not available then Install the Lan Card Driver.
  • You can install driver from this site Lan Card Driver
  • If Lan Card Driver is Install then check It is disable from the network places in the control panel.
Mar 05, 2010 | Intel D101GGC Motherboard
I have a system of intel d101ggc boar but problem is that the sound could not recorded from mic
conform audio driver working properly or not. then open control panel & opene Sounds and Audio Devices Then click on Audio then select your default device in Sound Recording then click on Volume & increase the Volume for Full Then Apply & ok.
I hope that this has been very helpful for you
Nov 12, 2009 | Intel D101GGC Motherboard
How can i get sound on my computer
This can have several fix scenarios. Go to Control Panel/Sounds & Audio Devices and check to see if the "Mute" is not checked. Or, double click your "Vol" icon in your taskbar to bring up your Volume Controller Panel. Check to see if your Volume is not muted on the source of your audio. If you have a Desktop PC, check to see if your external speaker system is plugged into the proper audio speaker jack at the rear of the Mother board or at the rear of your sound card. This is generally the green jack. Hope this helps.
Oct 11, 2009 | Toshiba Satellite A135-S2386 Notebook
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Mic not detecting
The Board have three sound port one for rear one for front and one for mic plug in the mic pin into the mic port red colored.
Then go to the realtek control panel located in the taskbar like a red speaker open it and go to the I/O
options and the mic options turn on front mic.
Jan 31, 2009 | Intel D101GGC Motherboard
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Intel Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
