Question about Channel Master Televison & Video
We need to reattach the wires to the Channel Master 9510A unit but are unsure which color goes to which post. We have a red, white and black on the tip wires. Can you help?
Can't wait around for your response, so I kept looking on the web until I found a users manual that showed how to connect the wirew.
Thanks anyway.
mt
Posted on Sep 13, 2009
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Dogs chewed up wiring from house to outside ac don't know what goes where
Wires used in AC for power are of different color like red for (+) black for (-) and green for (N). You can slice the rubber (about half inch) ends of broken wires and then reattach them matching the color, like red to red, black to black and so on. After that apply insulation tape on the joints. Make sure you switch off the power before you do all this work. If you are unsure, please call the AC service center and they will send an electrician to fix this.
May 13, 2011 | Heating & Cooling
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifierĀ“s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Wire hook up for Channel Master 9510A
wireing for channel master 9510
Jan 17, 2009 | Televison & Video
Cieling fan install
on the side with blue black and white the go color for color to the motor wires.
the side with red and white:
red goes to hot in ceiling
white goes to neutral in ceiling.
Nov 09, 2008 | Aloha Housewares (93645) Ceiling Fan
Televison & Video Logo
551 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
