I replaced my cartridge and the printer does'nt work
It says i have a automatic alignment problem it shows i have ink i have'nt changed the ink since i brought the printer.
It could be that the cartridges are not seated properly in the cartridge carrier or the encoder strip got unseated from its position. Please follow steps below to fix the problem:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. While the printer cover is open, check the cartridge area for a loose encoder strip (transparent strip).
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, re-insert one cartridge first.
  7. Close printer and check for any errors.
  8. If no error appears, reinsert your other cartridge.
  9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 25, 2011 | Lexmark Z2420 Printer
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Tried to install a refilled ink cartridge. Then
The printer working does not depend on its cartrage... Cartrage is just like ink in ur pen... If the nib of ur pen breaks then u cant blame on ink... Check whether the gare of ur printer moves if its nt then there is some problem in gare shifting ic or the rotator machine check it by giving it to some computer service shop
Aug 03, 2009 | Office Equipment & Supplies
Photosmart 2575 cartridges leaking.
when not in use Store them in a cool, dry, dust free place and you should not have any problems
Jul 27, 2009 | Office Equipment & Supplies
I put new color cartri#27 and new black cartri #17 and only use black
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Ink cartridge won't release
The replacement process isn't always very intuitive. Fortunately, HP.com publishes a web page with detailed instructions:
Replace the Print Cartridge
Good luck.
Oct 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Recalibrating a refilled black ink cartridge for a photosmart 7960
your printer probably cannot recognize one of both cartridges
clean the contacts of the cartridges and the contacts of the cartridge carrier  with a wet towel
if that does nt work your ink cartridge has probably overheated  because air has left in the cartridge after refilling and must be replaced
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
Sep 09, 2008 | HP PhotoSmart 7960 InkJet Printer
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
Photos
give your printer a DIAGNOSTIC TEST , is a cleaning test procedure of the ink cartridges, there you should know if you need to replace the ink cartridges.hope this helps AJ
May 08, 2008 | Canon PIXMA MP470 All-in-One Printer
14 people viewed this question
jasbo
jasbo
