Question about Toshiba DKT3020SD Corded Phone
Changing the user name
I have Toshiba DKT3220-sd and need to change the name on the phone. When i go into the system (500#*, 999# ...) and try to edit the directory name it will not give me letters, only the number on the keypad
Line by lumina 520
I had a computer system for a while
Feb 04, 2014 | Toshiba Dkt3220-sd Phones 3220 Ctx/dk Year...
DKT3020SD Corded Phone: HOW DO I DISPLAY THE CALLER ID ON A TOSHIBA DKT322...
Caller ID in POTS networks is a service which has to be subscribed to. The local exchange (to which the user's line is attached) has to allocate a DTMF sender for each and every incoming call, for it to be picked up by your phone and shown on its screen. Talk to your phone company for further informations.
Just my 2 cents... Carlos
May 16, 2010 | Toshiba DKT3020SD Corded Phone
I need to change the name that is displayed on my Toshiba DKT3010-SD. Please help.
Please follow the link below to download the complete manual for your Toshiba phone. It will answer your question, and you can print it for future reference.
http://www.craigcommunications.net/pdf/dkt-3000-2000-user-manual.pdf
Dec 11, 2009 | Toshiba DKT3010SD Corded Phone
Increase default volume setting on Toshiba DKT3220-SD?
Depending on what system you have it can be programmed in system programming. This must be done from Ext 205 and your manual can be found here.
http://guides.idacomusa.com/
Jun 04, 2009 | Toshiba DKT3020SD Corded Phone
Where is the Program button on the DKT3220-SD ?
press intercom #9876 HOLD, flexible buttoon pressed to assign, press the bitton code, press again the bitton to set DND = 180 short key for extn 610+extn number to change display name must set at administrator phone usually is receptionist phhone
Mar 17, 2009 | Toshiba DKT3020SD Corded Phone
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Dec 10, 2007 | Toshiba DKT-2020 Corded Phone
Toshiba DKT3020SD Corded Phone Logo
888 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
