Question about McCulloch 26cc Backpack Blower with Dual Jet Engine and Easy Start
Lost Manual need for repairs
I lost the manual and did some repairs on my blower, I wanted to make sure I had the fuel lines connect in the correct place.
  • 157 Answers
If the primer bulb fills with gas when you pump it then there correct if not swap places with them
Posted on Sep 18, 2009
  • 388 Answers
What does your carburetor look like? Does it have a primer bulb? If so, look in the fuel tank and find the uptake filter, it's a cylindrical looking object connected to a fuel line inside the tank. Trace that line (an easy way I did this was to blow into the fuel lines myself and watch the cylinder, the line that makes it bubble out gas when blowing is the supply line) BE CAREFUL if you do this, you do not want to inadvertantly swallow gas!
Anyways, the line connected to the cylinder is the intake, the other is a return line and needs to be connected to the primer bulb port...from there it's gravy! Hope that helps you!
Posted on Sep 15, 2009
Lost manual looking for quick start and operation
best way is to go on-line and down load a new manual. You'll need for general maintenance and such. Go to GOOGLE and type in:
LEAFBLOWERNAME Manual
Example: "Toro 3456 Leaf Blower manual" <<OR>>
"Toro Leaf Blower manual" and scroll through until you see you a picture of your leaf blower.
Oct 15, 2014 | Garden
Husqvarna Repair Manual
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
May 08, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
1993 Honda Dominator NX 650 fuel-vacuum-breather line routing
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1993 Honda Dominator NX 650 fuel vacuum breather line routing Google Search
http://www.eikholt.net/hpalt/download/NX650%20D%20Section%204%20%20Fuel%20system.pdf
1988 1989 Honda NX650 Service Repair Workshop Manual Download 1988 1989... $15
http://www.partsfish.com/page/oem-parts-for-honda
Honda NX500 Owner Manual
May 06, 2013 | Honda Motorcycles
All I want is a manual to make my own repairs if needed. This rototiller has set for several years. It fires but will not run. The gas is in the carb. How do I get the fuel tank off to get it clean and...
Purchase a repair manual at your local Tecumseh Authorized Service Center.
I suggest you get this engine professionally serviced before you strike out on your own. I recommend you treat the fuel with stabilizer as this piece of equipment is definitely seasonal.
Apr 26, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
My 2001 chevy blazer (v-6, 4.3L)., has a fuel injector problem and I would like to know how to repair the number 5 injector.
You will need to remove the fuel rail bolted to the intake manifold. There maybe a clip holding on the injector. Spraying some WD-40 on the ends of the injectors to aid removal, also when installing, spray some on the O-rings, will help in installing them. Make sure all are seated.
Mar 08, 2010 | 2001 Chevrolet Blazer
I lost my manual. What is the gas to oil ratio?
Your manual can be found here:
http://www.echo-usa.com/documentation.asp?Model=PB-251&lang=E
Please download a copy, IPL too.
Page 21 - Fuel Oil Ratio- 50:1 (2.6 oz/ 1 gal)
A rich mixture often causes hard starting.
Oct 29, 2009 | ECHO, Inc. PB-251C Handheld Blower
The engine revs high then low.
There is a way to remove fuel filter although I don't know if you can clean you might have to replace it. Other reasons for high and low revving could be that the carb might be adjusted correctly.
Aug 08, 2009 | McCulloch Trimmer Plus Attachment: Add On...
Fax cord lost
I think that that is a regular phone line type cable/wire. Check with your owners manual to be sure. If you have misplaced your owners manual then follow this link to download it. http://www.crutchfield.com/S-lYwGyrh5jMw/p_280MX300/Canon-PIXMA-MX300.html Looks to be a regular USB cable to connect printer to computer. If still unable to determine if this is the correct cable call Canon customer service at 1-800-385-2155
Hope this helps. Ratings are very important to us so I want to thank you in advance for taking a moment to rate my response.
Matt
Jan 15, 2009 | Canon MX300 Office All-In-One Printer
McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Jan 05, 2009 | McCulloch 26cc Backpack Blower with Dual...
McCulloch 26cc Backpack Blower with Dual Jet Engine and Easy Start Logo
202 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
