Question about HP PSC 1510 All-In-One InkJet Printer
Recommneded cartridges read as incompatible
Identical promblem as the person who posted this
HP envy 4500 is saying cartridges are incompatible? I just got it today.
The Incompatible Cartridge Message comes about because of several things.
  1. You are using Compatible Cartridges and the chips are reading as Empty - Replace the Cartridges
  2. The Chips on the cartidges are incorrectly fitted to the cartridges (Not contacting the Chip Reader in the printer). - Return them to where you bought them from for replacement.
  3. The Cartridges you have are full but Electrically faulty - Return them to the place you bought them from for replacement.
Dec 01, 2014 | HP Envy 4500 Inkjet Multifunction Printer...
"Incompatable print cartridge"
Follow this blog to fix your printer problems....read more
Sep 21, 2012 | HP Photosmart 8050 InkJet Printer
I have a Epson Stylus printer and the red light goes on .What does that means????
red light usually means a device error or failure.
check the basics like the cable , paper jam (open printer top, front, side covers and check for debris like paper clips, small piece of paper, etc.), also make sure that the cartridge is not improperly installed re-install cartridge and make sure the cartridge/s are installed properly you should hear a click noise when cartridge is properly installed), printer cover may also be not properly closed.
also, check that printer is supported by the computer's operating system. you may need to download and install the printer's latest software/driver for the computer's operating system.
Mar 01, 2011 | Epson Stylus Multifunction Inkjet Printer/...
When I switch the machine on the green light indicator shows In use / memory. It prevents normal functioning of the printer.
This scenario could be caused by incompatibility of cartridge or dirty electronic panels. Below are the procedures to manually address the two situations. Try them to get your printer working again.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
good luck & God bless!
Nov 14, 2010 | Canon Office Equipment & Supplies
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I have a hp 2600n printer. I have just replaced the black print cartridge because the yellow light was flashing and asking me to reorder supplies. Now the yellow light is still flashing the frist box if...
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 24, 2010 | HP Color LaserJet 2600n Printer
Printer won't print magenta colours cartridge is full only prints green
Hi suggest you read my post regarding the "cyan" printer problem...
it may help your problem as well...both problems appear identical...
cheers
haitchhcee
Dec 04, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epson R265 printer
ive had this problem too try putting the pollystyrene that holds the top of cartridge during transit back in when inserting cartridge into printer i found this worked for me
Feb 01, 2008 | Epson Stylus R265 InkJet Photo Printer
HP PSC 1510 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
