Question about Jenn-Air JGS8750 Gas Kitchen Range
Model S176W Jenn-air F-1 code flashing and beeping
I have been told it could be the control board which would be about 300.00, has anyone replaced this? Is it worth fixing or is it better to replace range. I bought it used I think it is around 15 to 18 years old. Can it be done by a homeowner (not to handy) or does a technician need to replace it.
    Problem Solver:
  • 7 Answers
Not sure what an F1 code is on that unit, but an easy check here,
shut off unit at breaker, remove face and unhook touchpad (ribbon) from the ERC. Turn the breaker back on, If the error code stops and it doesn't beep, the touchpad is most likely the problem. If it continues to beep and throw code, could be the Erc, (or something else telling the erc somethings wrong.) without knowing the F1 fault code, I wouldnt know where to start looking!
I would probably recommend a tech to reinstall the new Erc and or touchpad. Most new electrical components require extreme care when handling/installing, and a tech will know the proper procedures. Good Luck!
Posted on Sep 12, 2009
I have s176w jennair range that flashes and F1 signal and a makes a buzzing sound when I turn any burners on
F1 usually go back to the electronic control board. Unplug and replug the power back on. If error code comes back, replace board.
You might want to check all wires going to the board for anything unusual...make sure they are properly attached etc.
Oct 23, 2013 | Jenn-Air Kitchen Ranges
My jenn air s176w oven control buttons are not working. No response at all.
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
My jenn air s176w-c is not working it continiously beeps and a error code of f0 appears on the screen
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
Jenn Air model S176W
Heat and moisture (steam) kills the electronics in any control. but if the mark are on a circuit then there was a short in a circuit. I would check the series if your stove( first two numbers in the serial number)if it is a early series. for sure that they have make improvements in the control. And a Replacement controls will have all the improvement and revisions. good luck and let me know what you do..kraztech
Sep 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
535 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
