Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Turn key and ampmeter goes down but that is all. Starter? Solenoid?
  • 22 Answers
Battery
Posted on Sep 13, 2009
Is there a cilinoid on the simplicity riding mower 17hp
To find the Solenoid, follow the plus (+) cable from the battery. The other end will connect to the Solenoid. By the way, if you want to test your battery or ignition switch you can touch a piece of metal to both of the terminals on the Solenoid. Be careful of sparks. You could also disconnect the battery wire from the Solenoid and touch it to the other terminal on the Solenoid (which goes to the starter) If the battery is ok this will make the starter turn over even if the key is turned off. If turning the key is not causing the starter to operate, you could turn on the key and start the engine using the two methods I described above. The Solenoid is just a device to make a connection from the battery to the starter.
Touching a piece of metal, like a screwdriver for instance, to both terminals just bypasses the solenoid and sends twelve volts to the starter.
Jul 08, 2014 | Garden
All safety switches are engaged still cannot start with key. Able to jump start from mower battery to starter and shut off with key. Help ?
Sounds like it could be either the starter solenoid or the wire from the key to the starter solenoid. Try to energize the S pole on the starter solenoid and see if it cranks and starts. If it starts, the solenoid is not the problem so it could be the wire that goes to the start position on the key switch. If it doesn't start, it's the solenoid.
Jun 11, 2014 | Husqvarna Zero Turn Mower Z5426
2001 Buick park avenue, key turns, no crank no start
If your battery is in good condition, the likely cause is; the power is interrupted somewhere along the starter switch to starter solenoid. In my case it happened on one car when the engine had warmed up... if I turned the engine off I had to wait for it to cool down to make the sarter turn. On another car the problem started failing to turn the starter warm or cold, at the first turn of the ignition key.. later only after several tries, and later on after about a month, it didn't turn the starter anymore. I fixed them using a Ford starter solenoid... used to supply the starter solenoid directly from the battery, and actuated by the ignition to starter solenoid wire... If you're handy with tools, you can do it yourself and maybe save a few hundred bucks.
Coincidently I was looking for an image of the starter solenoid and found this article that describes the solution perfectly well. Hope it helps.
Goes to show how common the problem is. Hope it helps.
http://www.google.com.mx/imgres?imgurl=http://www.maliburacing.com/images/starter_solenoid.gif&imgrefurl=http://www.maliburacing.com/starter_solenoid.html&usg=__rVINcR6NUf2Vs63AcN158_sP4po=&h=403&w=599&sz=9&hl=es-419&start=4&sig2=JkqRNWCLIUocCVhe6nnqKA&zoom=1&tbnid=UZ8TVCjdUJg7jM:&tbnh=91&tbnw=135&ei=AdtoUJSKOOTUigLk3YG4CQ&prev=/search%3Fq%3Dford%2Bstarter%2Bsolenoid%26hl%3Des-419%26gbv%3D2%26tbm%3Disch&itbs=1
Sep 28, 2012 | Cars & Trucks
Looking to reinstall a solenoid for my 84 Bronco II and a buddy mixed up the wiring for it, i have no idea how to reconnect it to the new one.
Big wire from positive from battery goes to big stud facing the battery. Big wire to starter goes on other big stud. Little wire or wires go to little post. If you have 2 little posts they are labeled I (ignition) & S (starter). If you put on wrong little post it wont engage starter when you turn key to start. Just connect it to the other then it will engage starter when you turn the key to start.
Sep 09, 2010 | 1984 Ford Bronco II
I want to hit my starter to see if it will start up versus having a tow truck pick up and transport to shop. Where is the starter in relationship to the battery?
A big wire from the battery which is the positive terminal goes to the starter motor,and on the starter motor you have a solenoid,on it you have a thin wire that goes to the key switch,when you turn the key,then the solenoid turn the starter motor which switch on the engine
Jan 13, 2010 | 1996 Dodge Neon
My f-150 it will not turn over battery is good but not geting voltaeg to starter help
Use a test light and check at the starter solenoid and see if the ignition start wire gets hot when the key is turned to start. If it does check to see if current then goes thru the solenoid to the starter. If it does check to see if current gets to the starter, if it gets to the starter the starter is bad. If no current to the starter or out of solenoid the solenoid is bad. If current does not get to the solenoid when switch is turned, check and see if the current goes thru the neutral safety switch (Clutch switch if not automatic). If the current doesn't go thru the switch replace the switch. If you are not getting current to the switch in the first place check the ignition switch. If the current doesn't come from the ignition switch to the safety switch replace the ignition switch.
Oct 02, 2009 | 1991 Ford F150
Ford f100 engine 302 turns over when i connect the battery post .
YOUR BATTERY POSITIVE CABLE HOOKS TO THE BOTTOM LEFT SOLENOID.AND THE OTHER CABLE GOES TO THE BOTTOM RIGHT OF THE SOLENOID THEN TO STARTER.HOPE THIS HELP.
Sep 26, 2009 | Ford F-100 Cars & Trucks
The car has power but starter just clicks when turn the key its not the starter i took it out and had it rebuilt and replaced the battery any help would be very greatful
The solenoid for the starter may have bad power contacts. Older GM starters had the solenoid mounted to the starter itself. If this starter has just a heavy wire going to it, trace the wire to the solenoid--listen for the click while someone turns the key. Check the heavy wire on the other side of the solenoid which goes directly to the battery positive post. A voltmeter or test light is a handy tool for testing for voltage around the solenoid and the starter terminal.
Aug 06, 2009 | 2003 Cadillac Deville
1994 Dodge Intrepid clicks before starting
Weak battery or flaky starter solenoid. Check the condition of the wires betwixt the battery and the starter solenoid first. Also check the ground wire(s).
Mar 25, 2009 | 1994 Dodge Intrepid
Starter stays enegaged on 1990 mustang gt
sounds like solenoid is shorted to ground internally
Dec 02, 2008 | 1990 Ford Mustang
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
