Question about Kenwood Audio Players & Recorders
Kenwood receiver KR-A5020 Even strong FM stations sound weak and slightly distorted. Amplifier plays loud and clear from CD input. Thanks in advance Bo
5 Suggested Answers
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
SOURCE: I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
i have a kenwood kr-a4010 it works no sound in speakers
Posted on Jun 02, 2010
emissionwiz
  • 79077 Answers
SOURCE: kenwood kr-v95r receiver--the Fn doesn't
THE RADIO RECIEVER IS DEFECTIVE, THE COST OF HAVING IT REPAIRED IS MORE THAN A NEW UNIT COSTS, THE BEST THING TO DO HERE IS JUST REPLACE IT
Posted on Oct 11, 2010
  • 43010 Answers
SOURCE: How do I connect the TV to the receiver. An RCA TV Model #LED58G45RQ TO Receiver KENWOOD Model# KR-A3060 For Audio
If your RCA TV has left and right audio outputs on the rear, connect them to corresponding inputs on the rear of your Kenwood receiver.
Posted on Jan 09, 2017
How do I connect a Kenwood KR 5560 amplifier to my TV for stereo sound?
Your tv should have rcas out (white and red). Out of them to any input on amp.
Jan 27, 2018 | Kenwood Audio Players & Recorders
Why does the volume fluctuate when playing any connected equipment to my receiver?
You are describing one of the inherent problems in assembling various pieces of equipment into a complete system. Unless your Kenwood receiver has some provision for equalizing the various input levels, you will just have to adjust each one manually.
Dec 28, 2013 | Audio Players & Recorders
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Hola donde puedo conseguir el manual del receiver
Hola! Puedes buscar un manual por tu radio en el website de Kenwood por supporte.
Solo necesitas a buscar tu numero del modelo de tu radio y puedes copiar el manual ...no cuesta nada... checkas AQUI
May 30, 2010 | Kenwood KAC-9152D Car Audio Amplifier
2008 s40, i have no am signal but FM plays and CD no problem
There is a possibility that the radio is set to receive ONLY very high quality, strong signals. Maybe you are just getting the strong FM signals, and not the weak ones, and that all your AM stations are weak. When set on this mode, you dont hear the white noise of weak stations, the radio automatically blocks them out.
Dec 04, 2009 | Car Audio & Video
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Station memory problem
Sorry, I haven't addressed the station memory problem further since replacing the AC switch by-pass capacitor, which same didn't solve the problem. I'm using the receiver only as an amplifier for a Roku SoundBridge, so the station memory isn't a problem at present. When we return to AZ, I may look at it again.
Sep 04, 2008 | Kenwood KR-A3080 Receiver
No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Mar 06, 2008 | Sony XPLOD CDX-GT200 CD Player
628 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
