Question about Nikon D70s Digital Camera
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
  • 51 Answers
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Posted on Mar 11, 2010
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
Sep 26, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70: In camera Speedlight inoperative
Nikon D70
I Determined that the problem with the in-camera speedlight is internal and will send the camera to the Nikon Service center in El Segundo, CA for repair.
Thank you for your response.
Apr 21, 2008 | Cameras
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb 600 under exposure.
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Does Nikon D70 come with an additonal bottom to plug in Bowen Flashfill
Are you using the built in speedlight on the camera with the lens hood fitted? If you are this will cast a shadow. Try removing the lens hood when using the pop up flash.
Nov 27, 2007 | Nikon Speedlight SB-600 TTL Flash
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70s Digital Camera Logo
166 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
