I have the same problem
Back speakers are almost always dead, except for some rare occations for movie jingles and other fancy-start stuff. i have been very disatisfied with this product. i have been thinking it was me, but others semme to have the same problem
    Scholar:
  • 101 Answers
That is normal, The rear speakers are only to produce echos and not sound like the front speakers with voices. And they will only come on if you have a stereo signal or a 5.1 signal.
Posted on Sep 12, 2009
Nextar will not start up seems to be frozen the screen rolls I pushed the reset button and turn it off my computer does not reconize it Type your question here...
Hello
There is some software bug with your Nexstar. A bios bug problem is there. That is why, the computer does not recogonize your GPS. There is no software update for Bios. It can only be done by the authorised service center for Nextar at your town. Just contact them. On rare occations, Bios IC may need replacement. We can't get this component from open electronic spare part market. No components of any GPS, except its battery will be available at open market due to security reasons. No schematics or service manulas too. Just contact the authorised service center. Do not make any more experiments with this device please. OK
gopakumarg43 Fixya.
Oct 01, 2011 | Nextar M3-06 GPS Receiver
Changing the two back speakers in the 2003 Pontiac Grand Am
Always a good idea to upgrade speakers...Your factory speakers are normally removed from the underside of the rear shelf located in your trunk...6X 9 common size some 4 X 10...4 mounting screws on each corner, and a 2 wire connector...switch out is easy...some rare models have the rear speakers installed from the inside of the rear shelf...first check in the trunk for the speakers, and screws...if not there, you will need to remove the rear seat...to get to the speakers to switch out...first the bottom cushions then the top...bottom cushions have a large bolt on each side near the floor...top seat back bolts are under the bottom cushions...Hope this helps.
Jan 27, 2011 | 2003 Pontiac Grand Am
Help i just plugged in my kinyo speakers after not using them for a while and a "jingle" is playing incessantly, even over the sound of netflix movies...i can't find it! i restarted, everything else is...
I'm not sure what you mean by "jingle"..
The speakers are probably picking-up interference from a neighbour, radio-station, or -if occassional- a portable or cellular phone.
You can try moving the wires, or putting a snap-on filter on the wiring.. may help some.
Aug 31, 2009 | Kinyo PS-107 Computer Speakers
Ac line and compressor are frozen, turned off ac and let it thaw,happend again
This is almost always an air flow problem. look for clogged air filter, or anything blocking any vent. Make sure all vents are open. If evap is real dirty, it will do the same thing.
On rare occations, it could be a freon realated problem. Such as a dirty condenser or low freon level.
Good Luck
Aug 08, 2009 | Heating & Cooling
Fast forwarding movies and listening to movies without headphones
https://www.manualslib.com/manual/2384/Advent-Video-Mobile-Adv38.html#manual There is no speaker in this unit, so it's headphones only. The unit is not wired to an always hot fuse. Find a fuse that is always hot even when cranking the engine and the player won't start the movie over.
Apr 16, 2017 | Recoton Advent Advent DVD-8200 DVD Player
Yamaha DSP A-1000 input selector switch not working properly
i did not post that....and why would fixya be asking the poster of a problem for a solution?????
Bug? Pls delete these posts moderator.
ty
Mar 09, 2008 | Audio Players & Recorders
Tevion car radio 5705
Yes Phil, The radio will work on 2 speakers except, you should add an 8 - 10 ohm 10 watt resistor to the output wires of any speaker that is not hooked up ( to protect the audio output chip)
Good Luck
Ed]
NC Electronic
Mills, Wyoming
Jan 02, 2008 | Radio Communications
Boot error / No video out
Ajit,
The beeps are usually due to RAM or key board issues.
I would try by plugging it into a VGA socket of a monitor to see if it works.
Do you have heat problems? one suggestion is to try and reset the bios to default by moving the jumper on the mobo to do a hard reset.
good luck
Smeags.
Oct 23, 2007 | ASUS M2NPV-VM Motherboard
 Grubhead
Grubhead
