Question about Samsung Televison & Video
PC TO TV
MY MANUAL FOR MY TV IS FOR WINDOWS XP
BUT I HAVE VISTA
HOW DO I CONNECT THEM TOGETHER WITH STANDARD CABLES
  • ray8047 Sep 12, 2009
    do i have to do anything with the pc first?
    its just that my pc screen is off because its plugged into tv
  • k24674 May 11, 2010
    Hello, Did you try to use the same type of connections as in WinXP? Despite the hoopla and buzz about evere thing new, very many things are not changed. Hope it helps.
    President:
  • 1,015 Answers
The TV will recognize any operating system. You can use a VGA cable to connect to the television if the TV has a vga port. Then select the PC input for the TV. If the connection is white and larger if may be a DVI connector. You will need a DVI cable in that case or a DVI to vga adapter.
Posted on Sep 12, 2009
Wont connect to pc
Thanks for visiting FixYa!
Your phone connects to your PC through either 'Active Sync' (for windows XP) or 'Windows Mobile Device Center' (for Vista or Windows 7).
After downloading the program you need, restart your PC then connect the phone to your PC with a USB cable.
Click to Download: Active Sync (Windows XP)
Click to download: Windows Mobile Device Center (Windows Vista / Windows 7)
Sep 10, 2011 | HTC HD2 Smartphone
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
I'm trying to capture video from my sony dvcam dsr-pd170 onto my laptop but can't a wire that will hook up the two devices together. What type of cable am I looking for?
Hi, you have a choice of USB (If you are on Win XP or older Windows) or Firewire cable if new Vista or Win 7 okay? or you can use the standard Red/Blue/Yellow connector cables, 3 in camera, 3 to the PC, mostly these sockets will be on rear of PC close to Speaker socket.
Take care,
David UK
Jun 21, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Connect tv to computer
Be sure to enable the second screen through the windows display settings. Right click on the desktop background and select personalize (VIsta) or Properties (XP). Click on the settings menu (lower down on Vista, a tab on the right for XP) and look at the monitor setup. After you are connected via cable to the TV, go there, click on the second screen and select "enable this monitor", "extend desktop onto this monitor" or something of the like. Oftentimes it will not do it if you are not already physically plugged in so ensure that you do that first.
Aug 26, 2009 | HP Pavilion Elite M9150F Desktop PC
I WANT TO CONNECT MY CHINA MOBILE TO PC AND I WANT PC SUIT FOR VISTA PLEASE
please remember that most pc suites except standard ones like nokia and sone ericson do not work properly on windows vista due to driver compatibility problems. you can get a data cable for the model you have from the local mobile shop itself. but getting the exact pc suite to work in vista is a bit tough one. so go ahead either with windows xp or connect your phone's memory card with a memory card reader with the pc
Aug 19, 2009 | Lands Phones
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
How to connect vista to internet
Oh, then there is a problem with the PC. I have Vista Home Premium and I connect to a network made by XP and majority of them are XP, for Internet. All the new versions of Windows are made to be compatible fully with the old ones.
Dec 11, 2008 | Microsoft Windows Vista Ultimate Edition
Desperately need Panasonic NV-GS50 USB driver for Windows Vista. Does it exist please?
Connect to your PC with a 1394 cable. When Windows Vista finds it, it will install the driver and you are ready. I did this after first connecting with a standard USB cable and getting a "compatability conflict" message. Now I am up and running.
Should this fail to work, contact Panasonic Camcorder helpline on 0844 844 3869.
Dec 10, 2008 | Panasonic NV-GS50 Mini DV Digital...
Will I be able to connect to a computer with Vista?
you can connect to any XP pc to a Vista pc, using adhoc (joining two together via ethernet cable to share files and internet connection) or via a router.
Sep 05, 2008 | Belkin Computers & Internet
Dont know how to connect the my windows XP laptop to my Panasonic Viera HD TV using the BELKIN PC-DVD to TV cable.
if your laptop has a s-video output you can use a standard s-video cable to connect to your tv.
Aug 30, 2008 | Belkin Computers & Internet
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
