Question about Canon Cameras
How do you use it ...in laymans terms....settings etc. thanks
How do you use it ...in laymans terms.....100-400mm l is usm lens
  • cemery Sep 12, 2009
    THANKYOU ...I GUESS I WANTED TO KNOW I HAVE PROBLEM FOCUSING IT......WONDERING IF IT IS ME OR THE LENS......LIKELY ME ...I AM SO NEW TO PHOTOGRAPHY AND STIL LEARNING.........USED TO THE SMALLER LENS.......
    Brigadier General:
  • 4,090 Answers
Your question ( in laymans terms) is unclear! But I will make a guess as to what it is you ask.
The 100-400mm is the focal length of the lens, To use it it has to be attached to the camera It it is capable of focusing clearly on an object at its maximum output as well as its minimum. At its maximum focus it can perhaps ( depending on optical quality) bring an object 4-5 Kilometers into clear view. Most lenses have a zoom factor and a focus ring. Experimentation with the lens will be a better way of defining what improvements it has over a standard 50mm lens
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 12, 2009
17-85mm err99
My initial tests revealed it might be with this lens, the Canon EF-S 17-85mm f/4-5.6 IS USM, might have been causing the error. Yet, I still have to do more rigid tests, as when I attached back this lens after rubbing off gently its gold contacts, error was gone again.
try it yourself.
thanks.
May 11, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
USM Motor Problem?
check the stablalizer setting on camera. could be on continous setting instead of on demand.
Mar 24, 2010 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Canon 75-300mm USM III, was initially working fine
Hi
you seemed to have a problem with the camera (auto-focus) mode. I suggest you try shooting in manual focus only but consider taking it to a canon service outlet for proper checks and service as a long-term solution.
Apr 04, 2017 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Canon 70-200 2.8L IS USM Lens
Its modes for the IS
mode 1 is for general use
mode 2 is for when panning horizontally.
good day
yitzy
Oct 18, 2008 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Data transfer
sir i dont know laymans terms but in english i can explain to you on how to transfer your videos to your computer.
Sep 19, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Canon EFS17-85 mm Image Stabilizer Lens stuck in Macro mode.
The USM focus works by applying pressure to a set of rollers. That pressure is achieved with a large diameter spring washer. It is held in place by another large diameter flat washer that on assembly is rotated 60 degrees to lock it in place. If the lock washer has moved due to mechanical movement (ie rapid manual movement of the focus ring) it could unlock and then all pressure to the USM motor parts and rollers is lost giving the loose feel you mentioned.
You will need to dissassemble the rear of the lens to see the USM motor parts, rollers and locking ring to reattach it. Follow the links at my pbase gallery to see the dissasembly. When I took my lens apart the focus and USM motor went all loose and I wondered how could it work ever!!!. The locking ring was off which sounds just like your fault. http://www.pbase.com/barry_2718/efs1785mm I also have a flex cable cracked which is a much harder fix. Take careful note of the parts (mark then with a felt marking carefully) to achieve a reassembly exactly as removed.
Apr 05, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I have a Canon EF 300mm f/2.8L USM Lens
Here is a link to many Canon products in PDF form: Canon Parts Lists
Unfortunately, the only 300mm 2.8 lens listed is the IS version
The procedure is not that complicated, but you need to pay attention to the connections on the circuit board. The mount is removed, and you need to remove the small screws that hold the connector board to the mount ring first.
I cannot do live chat due to I use a Mac, but I will monitor the thread if you have questions,
Kevin
Mar 24, 2008 | Canon EF 400mm f/4.0 USM Lens
Broken ring around 75-300 zoom lense
Hi Pamela,
You can order directly from Canon USA,
Canon's info: To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
Jan 30, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Cameras Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
