Question about GN Netcom 9020 Consumer Headset
Replace battery the GN9020d battery is pretty much dead - instructions indicate I must return to factory to replace this - Any other choices? Also I have a back-up set but the mute tone is super low - is this something that can be increased?
0 characters
1 Points
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Headsets
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Just bought the samsung hm 1100 bluetooth headset and i tried plugging it in to charge it and no light comes on at all it has just got really hot any ideas why its not working ?
If it gets really hot this indicates a short in the charging circuits or battery, this is clearly a manufacture defect and should be returned for exchange.
Jun 22, 2011 | Samsung HM1100 Bluetooth Headset
My Plantronics .Audio 995 wireless headphones refuse to charge with the cord provided me or any other one I substitute it for.
It sounds like the battery is dead in the headset. That headset has a non-replaceable battery. If the .Audio 995 is still under warranty you should have it replaced. I have included this link to the Plantronics .Audio 995 User's Guide.
Apr 16, 2011 | Plantronics .Audio 995 Digital Wireless...
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
My headset will not hold a charge CS70VT
The only thing is to check the voltage output by the charger... usually 5 volts. The lights MAY blink even if voltlage is too low.
If it is OK, then battery in the headset has failed. Have the battery replaced or DIY if not under warranty.
The usual cause of this is to continue using batteries under load when one of the cells is totally depleted.
Nov 09, 2009 | Plantronics CS70 Wireless Headset
Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
HS820 "dead"? No blue light
Toss it. They aren't replaceable. You have to break open the case (glued shut). Even if you opened it, the replacement would likely cost you what it would to replace the whole unit.
I'm in the same boat.
Nov 20, 2007 | Motorola Mobility HS820 Consumer Headset
Very poor battery life
Just another made in Chine "Amero" peace of shitt
Mar 22, 2007 | Motorola Mobility H700 Wireless Headset
GN Netcom 9020 Consumer Headset Logo
96 people viewed this question
Top GN Netcom Headsets Experts
Steve Morris
Steve Morris
Level 1 Expert
Tom Chichester
Are you a GN Netcom Headset Expert? Answer questions, earn points and help others
