I am setting up a Linksys Wireless G Router and can't find how to set up a password
  • lrgnet May 11, 2010
    typehttp://192.168.1.1 user/pass could be admin/admin; admin/password; admin/1234. When you say password, do you mean the password to login to the linksys or the encryption key?
  • 17 Answers
Hi there..
you should go to the service page.
open internet explorer or mozilla (or any other internet browser that you are using)
type on the address, 192.168.1.1 and you'll be prompted for a username and password.
key in (username) admin and (password) admin
then you should be able to access the service page.
click ont he tab which says, wireless - wireless security.
from there you can input your internet setting to whichever security levels you want.
WEP/WPA/WPA2. which ever you need.
If you need to change the password to your router, navigate to Adminstration tab and change the password to the router.
Posted on Sep 12, 2009
    President:
  • 1,015 Answers
You can get to the router settings menu by entering 192.168.0.1 or 192.168.1. in internet explorer. It should ask for a password and default is usually "admin". Once you are in the settings for the router you can configure the security settings for WEP. When you activate it you will create a password that all computers on the wireless network will use to connect to the router.
How will i change the password of my WAG200G router,and how can i access my linksys to change password
Do you mean the router's login password or the encryption password?
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 27, 2012 | Linksys WirelessG ADSL Home Gateway...
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
I forgot my password
Which password you are looking for?
If you are looking for wireless network password then you will need to access the router setup page and check the wireless settings.
IF you are looking for password to access router settings then default password of Linksys router is admin.
To check the wireless network password see How to find wireless network key WEP WPA
Jan 08, 2012 | Linksys Wireless-G Broadband Router
I need to set a password for my Linksys Wireless-G WRT54G Router, but the websited 192.168.0.1 to set the password isnt working. I need help ASAP. Thank-You
to access the router page for linksys, you need to type 192.168.1.1 on the address bar. username is " admin " password is " password " if it doesnt work, try "admin" for username and "admin" for password. then it would take you to the router page. and you can start configuring.
Sep 09, 2011 | Linksys Wireless-G WRT54G Router
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
Need help setting up the Sudenlink Modem to Linksys Router
Connect lan cable from modem to linksys router's WAN port.
Then configure linksys router with below method.
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set as your internet service provider settings like static ip address.If service provider give you user and password for connect internet then set router in pppoe mode.
Enable DHCP.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 18, 2011 | Linksys WRT160N Wireless Router
Change my router password
Click around once you're in the settings. There should be a setup tab with the password change somewhere.
Mar 12, 2011 | Linksys WRT160N Wireless Router
How to change linksys wireless-G broadband router password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP security change the password and save settings.Then restart router then you can connect wifi with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys Wireless-G Broadband Router
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys router G - buddy forgot password I am at my brother-in-laws home for the week and they don't know the username and password for the linksys but they do have custom settings. How can I just reset...
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Jul 01, 2009 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
