Question about Cuisinart DCC-1200 Coffee Maker
How do I set the time on cuisinart coffee maker model cbc-00? Regular time 12 hour intervals Thank You
  • 2 more comments
  • Anonymous Mar 14, 2014
    Were could I get a manual for the cuisinart CBC 1600?
  • Anonymous Mar 23, 2014
    correct water filter for cbc-00 series coffeemakers??
  • Anonymous Mar 30, 2014
    my machine will not turn on
    how do i take the face plate off
  • 8,596 Answers
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Posted on Sep 29, 2009
In my CBC-00, there was a hard filter inside the filterholder basket. It accidently got thrown away and now I cannot find a replacement online. Any ideas about how to find one? Thanks!
Contact the manufacturer directly and see what they can do. We have no other resources here. If this uses a standard cone filter you can buy a generic on line. I have one in use right now.
Jul 20, 2016 | Cuisinart Brew Central Coffeemaker 12 Cup...
Cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
Jun 28, 2010 | Cuisinart DCC-1200 Coffee Maker
I have lost the manual for the Cuisinart Brew Central, model CBC-00, coffee maker. My question is this: What the "carafe temp" knob does with L and H selections? I assume it is to select the carafe...
Hello pdmkali,
Your assumption about the carafe temps is correct. The middle position gives you a medium temp, of course. I use it on low so that I don't burn my lips and tongue when I drink my coffee. Thank you for the opportunity to answer your question. If it is helpful, please leave positive feedback for me. It is appreciated. Regards, NormanZ :o)
Jun 28, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
1,514 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
