Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Screen come on then goes black
When I turn the monitor on I get a brief visual of the desktop then it goes black.
    Scholar:
  • 53 Answers
The most common problem. It is related to old backlight lamps. The best solution is to replace them, but if you don't care a lot about total brightness, you may simply replace faulty lamp with 27pF 3kV capacitor, soldered across the high-voltage connector. That would be equivalent load for the inverter.
First of all, you need to find which lamp causes that problem. Disconnect flat cable from the display so all backlight will go through the screen. Now, using that 27pF capacitor replace lamps one by one and check when the light will stay for longer time. Keep that configuration as temporary solution, but make sure you will isolate your capacitor well, 'cause there's about 1000 volts applied to it.
Posted on Sep 13, 2009
I have a gateway dx4200-09 and when I boot up the screen goes black a few seconds after we turn it on and can't do much without visual have to constantly turn on and off monitor for brief glimpses
Either the Monitor or Video Card is going bad. Since it comes back on by turning the monitor off and on, I suspect it's the monitor.
If you have another monitor, plug it in and see if it works. If so, the problem was the monitor.
If you have another computer, plug the monitor into it and see if it works, if so, the problem was the video card.
Mar 26, 2012 | Gateway Computers & Internet
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Lg l1920 lcd monitor's screen flashes when turned on
Could be an inverter problem, if it powers on for a brief second and then flashes off then the inverter is at fault. Check for any Capacitors which have a yellowish substance at the top, they looks like round blue or black cans and if they look like they are buldging then they will need replacing.
hope this helps =]
Feb 11, 2009 | LG L1920P 19" LCD Monitor
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
LCD monitor from "LCD Universe"
Inverter unit inside the screen may be defective
Apr 07, 2008 | Computers & Internet
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
389 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
