Question about RCA HD52W59 HDTV Projection Television
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
  • RCA Master
  • 8,617 Answers
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Posted on Sep 13, 2009
Mitsubishi convergence issue
First is consider what the issue is: nothing moves convergence wise or only one color etc.
Also follow if needed the voltages from the pico fuses involved---one will be a negative voltage and the other a positive one--follow them from the diodes for each voltage to the chips---"Got Voltages?"
Jun 11, 2012 | Mitsubishi WT-42313 42" Rear Projection...
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
I have a r56wh78 rca tv that the colors wont converge, can it be fixed
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
Convergenc problems w/ RCA HD52W59 HDTV
sorry but u replace the incorec part , the board which control the convergence voltage on and off is the deflection board , now this board is about $100 - 150 , or if u want to fix it , just solder the flyback , just go to radio shack and get a 25watt solder station and solder rosin , also check for bad fuse , this fuse it dont look like the others , this is a 1/2 watt 250 pico fuse , and is next to the flyback , look like small brow squer little box , there is 3 and the one that is bad is the one in the middle , this 3 pico fuses are togethere u cant miss then , good look
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 tv loses convergence every time I turn it off. it has been a problem off and on for almost 2 years. Coincidently kicking the tv fixed it for several months. It is worse than ever now. How do...
this is an easy fix , ur problem is on the deflection board , look at the flyback transformer it is a big black component there is loose connection u need to do soldered connection on the flyback than check a pico fuse look like a squer little box brow color , look very care full at this pico fuse u need a metter to check for continue the value is 1/2 watt 250 volts
Apr 13, 2010 | RCA HD52W59 HDTV Projection Television
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tv shut off and started clicking
Do you hear a constant chirp or click?
If so you will most likely need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 12, 2009 | Philips 60PP9363 60" Rear Projection...
Kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Jan 03, 2009 | Sony KP-46WT500 46" Rear Projection...
How to find the convergece amps
On that chassis the only fuse affecting convergence is a 400ma pico fuse near the flyback transformer. If this fuse is open the signal board will never send the "ON" command to the convergence supply so the convergence will be dead.
If the pico isn't open then suspect the amps themselves or possibly an open resistor or two.
Bill
Dec 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
257 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
