Question about Whirlpool GEW9250P Electric Dryer
INK PEN IN DRYER INK MARKS ALL IN DRYER HOW DO REMOVE INK
HOW DO I REMOVE INK MARKS FROM INSIDE THE DRYER
    Brigadier General:
  • 4,090 Answers
Use a cotton ball with a small amount of Eucalyptus oil and wipe clean.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 12, 2009
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
Somehow a ball point pen went into the dryer. I now have ink on the inside of the drum. What can I do to get the ink off the drum. It should be noted that the dryer weny through a complete cycle before...
You may have to experiment with solvents to find one that will remove the bulk of the ink. Start with rubbing alcohol, then try a mineral spirits (paint thinner) or WD-40 oil, and finally some acetone. Make sure there are no sparks or fire nearby while using these solvents. Be sure to clean the areas with a spray cleaner after any success to remove a lingering smell. You may have some permanent stain left that will just have to wear off, but shouldn't affect your clothes. Hope this helps!
Dec 11, 2010 | Whirlpool Dryers
Pen ink stains on dryer drum, help!
use liquid solvent...thinners or maybe even some petrol from the lawn mower.... a little on a rag should do the trick,maybe some metho or even turps.
Jul 20, 2010 | Kenmore Elite HE4 Electric Dryer
I get black marks like a crayon or ink line on certain light colored shirts after washing my clothes. Not sure if it's coming from washer or dryer. I use a stain remover and it's not coming out completely.
is the black marks grease look under the bottom of the machine and look on the side walls of the machine if u have a line of grease around both sides then you would need to change the transimission on the machine if it is not grease and you determine that is pen u might try looking in between the two baskets.And lastly ihave seen pen cartriges enlodge inside the pump which does cause the pen to leak hope this helps
Jun 26, 2010 | Washing Machines
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
INK PEN LEFT IN DYERS NOW INK MARKS ALL IN DRYER
try some OOPS Just make sure before you run drye again, you have wiped out inside because OOPS s flammable.
Sep 12, 2009 | Whirlpool LER4634J Electric Dryer
The inside of my dryer is turning blue!
It sounds like a fountain pen may have exploded in there. If the drum is blue from something like ink, the best stuff I have used to remove ink from a dryer is some stuff called "Goo Gone". You can find it at department stores like Wal-Mart, etc. Hope this helped and best wishes.
Aug 15, 2009 | Dryers
Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Whirlpool GEW9250P Electric Dryer Logo
338 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
