Question about Kenmore 98702 Stacked Washer/Dryer
Washer problems The washer will not start. At regular wash cycle, there is no water, nothing. The machine is plugged in, water is on, fuses work, except for the machine. Worked fine last night, Sunday, December 9, 2007, but nothing tonight. PLEASE HELP ASAP! Please call 314-495-7422. Sincerely, Don Henning Kenmore Customer
    Scholar:
  • 146 Answers
How old is the washer? Some washers you can pop the top on if so check your power cord as it enters the washer. There may be a loose or burnt wire at the terminal block. Some washers won't start if the lid switch isn't making. Check that also.
Posted on Dec 18, 2007
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Have a Whirlpool Cabrio washer WTW6400SW3 went thru wash wash cycle, then started to drain water to go into rinse cycle. Half way thru draining, was a loud electrical pop in control area of washer and...
sounds like a shorted machine due to water or moister? In most case you had a fuse blow on the machine somewhat like a thermal shut off fuse, most likely located in the panel. if this is the case u need to find out what shorted it, how water or moister got in? You can also look at the control curcuit board and look for burned seized transistors or areas indicating a burned out board.
Feb 11, 2015 | Whirlpool Washing Machines
Kenmore washer machine cylce stopped in mid cycle
If your washer doesn't seem to work at all, check these:
  • No power
  • Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Washing machine
it is possible the heater is at fault try this first / then check motor / after these there could be an exposed wire shorting on the chassis . always remove plug from mains when carring out checks . good luck
Apr 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Indesit WG1235T O
I would say the doorlock switch is faulty
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
