Question about Dryers
Long drying time
Dryer is taking much longer to dry, perhaps a thermostat? No vent blockage, good air flow.Color of gas flame looks good. Seems like it does not get hot enough.
    President:
  • 1,922 Answers
Check your thermo-couple
Posted on Sep 12, 2009
I don't hear the electronic ignighters
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
replacing whirlpool gas dryer ignitor not heating www goodappliancesupersto... How to Fix YOUR gas Dryer that is not heating up Part 1 rear panel
Jan 04, 2017 | Dryers
How to fix a whirlpool gas dryer that tumbles but no heat ?
Air Flow and Heat
Warning
Apr 12, 2015 | Whirlpool Dryers
Gas dryer throws reset after a few minutes
Air Flow and Heat
Warning
Apr 07, 2015 | Dryers
My lg gas dryer will run alright just will not dry clothes.The flame will ignite for maybe 10 seconds or so and then shuts off.It keeps repeating. I know it sounds like my flame sensor needs cleaned.
I would check the vent and be sure it is open and free of lint. That would be the easiest thing to check. If you have the flexible white duct replace it, it is a lint trap.
Apr 02, 2015 | LG Dryers
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Air Flow and Heat
Warning
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Flame keeps going out after 5-10 seconds
Thermal Fuse
Air Flow and Heat
Warning
Aug 18, 2014 | Dryers
Drying time too long
You are going to want to check and make sure there is proper air flow from the vent outside the house. If it feels weak then you will need to get it cleaned out. If enough air is not exiting the thermostat will shut off the flame for safety reasons. If your air flow seems to be working okay then it may be a problem with the thermostat. Let me know if you have any other questions and let me know if this was helpful. Good luck and I am glad i could help.
Jan 22, 2009 | Maytag Dryers
Gas dryer not heating properly, burner ignites at start up, then not again
Please provide the brand and model number of your dryer.. However.. you state that your dryer is not heating properly and yet the burner ignites.. If you have a flame after ignition and your dryer is drying slowly, I would be inclined to look at the blower and or vent for restrictions in air flow. The heat generated by the burner will not be optimized in terms of drying clothes if you do not move that air out . Any and all restrictions to normal vent flow will make the dryer less efficient and dry times will be longer. If you are bound an determined to get into the flame sensor and thermostat logic, then please provide a brand and model number..
Hope this helps...
Sep 06, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
