Question about Kenmore 22422 Top Load Washer
Kenmore model 80 topload waher: does the agitator cap just pull off? don't want to break it.
  • 126 Answers
Cap pops off,remove pull up cover and find 7/16 bolt holding agitator to trans.
Posted on Sep 13, 2009
Hello, I have a Heavy duty 80 series topload washer, model# 110.92380200, and the top section of the agitator does not rotate. The bottom turns, but the top does not. If you have any ideas on how I...
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 06, 2010 | Kenmore Washing Machines
How do I replace the agitator on my Kenmore 80 series
First thing is to take the cap off the middle (where you add the soap). Once that is done, look down inside and you'll aee another lid thing( not in all models). Remove that and then you will see a 7/16 bolt directly in the middle. Get a socket wrench with an extension and remove it. Pull the agitator out, and insert the new one. Put the bolt back in and everything else and your done.
Nov 03, 2010 | Kenmore Washing Machines
The agitator is slipping on our Kenmore 80 series toploader. I'm not sure how to remove it.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Assuming that only the top section of the agitator is "slipping, the problem points to the Agitator "Dogs"
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=8878c06f855a89c90959d53553cf9ab8
If it's not the "Dogs" see the following that has a section on how to remove the agitators and check the splines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 02, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 washer extremely poor agitation works if pressing
YES THERE IS! REMOVE AGITATOR BY TAKING THE SCREW OUT UNDER THE CAP. PULL UP ON AGITATOR TURN UPSIDE DOWN WILL FIND 4 AGITATOR DOGS REPLACE THESE AND REINSTALL AGITATOR WILL WORK LIKE NEW PART NUMBER IS 80040
Apr 30, 2009 | Kenmore Washing Machines
Washer won't spin
pull the fab soft dispenser out and pry off the cap that sits on top of agitator looking down inside there you'll see 4 pieces called agitator directional cogs(dog ears) they are worn and need replaced
Apr 06, 2009 | Kenmore 22422 Top Load Washer
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
"dog ears"
hi go step by step and you'll do great http://www.american-appliance.com/service_pages/wp_dd_wash/dddogreplacement.htm minor changes are possible good luck
Mar 29, 2006 | Kenmore 24642 Top Load Washer
Kenmore 22422 Top Load Washer Logo
59 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
