Question about Kirby G6 Bagged Upright Vacuum
Belt ~ Why is this so complicated?? No manual
We just recently moved and I can't find my user guide anywhere. It's been awhile since I've used this vacuum and I can't remember if the belt needs to be hooked up or not when running the regular floor mode. I left it unhooked and the suction doesn't seem to work that well and I'm scared to burn up my belt. So I either have a suction problem or a belt problem.... ;-)
  • 4 more comments
  • spaz31023 Dec 16, 2007
    How to replace belt in a Kirby G6
  • Anonymous Dec 24, 2007
    very complicated..... the belt is too tight and won't turn all the way to the Belt Off arrow.
  • Anonymous Jan 12, 2008
    Can't get the belt to stay on vaccum.
  • Anonymous Feb 07, 2008
  • tjkc Mar 26, 2008
    same problem - need help now!
  • bopparules Apr 24, 2008
    cant rememeber how to put new belt on
These instructions were excellent! They really helped me find a solution to my problem and they were easy to understand!
Thank you so much Marci!
Posted on May 03, 2008
  • 357 Answers
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Apr 21, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush stays on when upright
You are correct, the brush will continue to rotate when using the upholstery hose as stated in the user guide.
The burning smell may be contributed to a couple of different reasons. Make sure the front of the vacuum is not being tipped or tilted forward when using the upholstery hose.
If you continue to have difficulty, you may want to have a one of BISSELL's Authorized Service Centers inspect your vacuum.
Here's a quick link to locating one in your area:
Mar 12, 2013 | Bissell 3522 PowerForce Bagged Upright...
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
Brand new bissell #6583 upright vacuum worked for 15 min
The belt may be broken. The following link is to the User's Guide which explains how to check and replace the belt if needed.
Jul 14, 2010 | Bissell 6594 PowerForce Bagless Upright...
Change belt on proheat bissell 8910
I have added a link for the owners manual for your model and a link for the replacement belts you need.
8910 User Guide (PDF)
Bissell Proheat 8910 Replacement Belt
Oct 30, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
May 17, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Power problem
Hi, Try logging your post on the Kirby Trading Forum at - you'll be sure to get a reply. John
Aug 03, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
97 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
