Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frs20wnf how do u replace the water line on the door. water line needs replace
    Sergeant:
    Champion:
  • 323 Answers
Youl have to remove the door skin and access it that way
Posted on Sep 12, 2009
The water dispense not work ice is good.
Check water line from bottom of freezer door open line if you have water there when activating water arm then you have frozzen water line in door common GE problem need heat strip added in side door GE has a kit for that
if there is no water at door then replace water valve in back of ref bottom under cover freezer side
Jan 30, 2013 | Refrigerators
Internal waterline broke
i would need a model number because in most cases if the water line broke in the door, you would have to replace the whole door assembly.
Dec 30, 2012 | Refrigerators
While water is being dispensed through the cool water outlet, water leaks thru the flexable line at the bottom of the freezer compartment door. Whats the problem, and how can it be fixed?
Due to water comming from the bottom of the dooe , you will need to replace the door water line . Pt # WR17X10206 is the replacement line . Remove the upper portion and " feed " the new line down thru the freezer door .
May 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Is there a filter on the water for my Refridgerater Model #FRS20WNF. If so where can I buy a new filter and how do I replace the existing one? The water is starting to taste funny.
HI. This unit is not equipped with a water filter. If there was a filter, it would be located on the front/lower grill area(bottom part of your unit). It would be accessible there.Unfortunately, this unit dose not have a filtration system.
Oct 22, 2009 | Frigidaire Refrigerators
My Frigidaire model number is Frs20wnf My refrigerator does not make ice. There is water in the door. I hear all of the sounds that it made when it was making ice.
first we have to manually see if we jump the water valve if there is water then. if yes could be the ice maker bad, if no could be the water valve or you water line is frozen inside the freeezer... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | Refrigerators
Water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Apr 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replacing cam and shim
on the right side door just take off the top hinge (three screws or bolts on the top of refrigerator) and lift the door off of the bottom hinge.
left door is the same but you have to disconnect the water line and electric line that goes to the door. the water line has a coupling behind the kick-plate on the bottom of the refrigerator. the water line then slides up thru the hinge( BE VERY CAREFUL WITH THIS SHORT LINE COMING OUT OF THE DOOR, IT IS ALMOST IMPOSSIBLE TO REPLACE)
Jun 28, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
