Question about Frigidaire Washing Machines
Water drains after spin but clothes are still wet
  • hotsauce7489 Sep 12, 2009
    TIDE with bleach alternative detergent and loads vary from medium to large
  • hotsauce7489 Oct 25, 2009
    Hi, i recently fitted a new belt on washer and ever since it does not spin out washing,the motor is running at speed and the belt is tight....excess water in tub and no spin at all..also timer is jamming and i have to manually move it on ..:) ty if you may have any ideas at all
    Problem Solver:
  • 7 Answers
What type of detergent are you using, and how much per load(small, med, large)
Posted on Sep 12, 2009
  • fastactracin Oct 25, 2009
    check to see if the tide your using is the 2x concentrated. I have been running into this a lot lately. If it is you probably have been using too much. I know thats never what anyone wants to hear, but if the machine is doing everything its supposed to do, and clothes are still wet, i would lean on a suds issue. With these new detergents, a little goes a long ways... Easy check- next load use the normal amount of detergent that you would use, once the agitator engages, let it go for a few minutes and look in the tub for excess suds... let me know from there
    gb
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Clothes wet when cycle is done
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt , a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | Whirlpool Washing Machines
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Apr 01, 2009 | Bosch Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
