Question about Car Audio & Video
Need to replace factory pre-amp for another brand and change wiring to and from amp . have a mitisubishi 2003 ,v6.
I need to connect my pionner navi to my alpine V-12 amplifire step by step
Posted on Sep 12, 2009
How to wire up an ignition on a 1999 mitisubishi Montero sport
PDF]MITSUBISHI MONTERO SPORT 1997-2004 VEHICLE ...
alarmsellout.com/.../MITSUBISHI%20MONTERO%20SPORT%201997-...
WIRING INFORMATION: 1997 Mitsubishi Montero Sport. WIRE ... WHITE. IgnitionHarness. STARTER WIRE ... This must be bypassed when installing a remote start system. ... WIRING INFORMATION: 1999 Mitsubishi Montero Sport. WIRE.
Montero Sport Starting Problem - YouTube
? 2:35
https://www.youtube.com/watch?v=TZCbEmfi3JM
Nov 2, 2011 - Uploaded by aaron1969lopez
Im not sure what is causing me to have trouble starting myMontero Sport. ... 2001 Mitsubishi Montero Sport ...
1997-2004 3.0L V6 Firing Order -Ignition Coil Spark Plug ...
Dec 08, 2015 | Cars & Trucks
Volume from turntable too low
Have you got it connected to a dedicated "phono" sockets that has an in-built pre-amp for it?
If you haven't got one you might need a magnetic cartridge pre-amp.
If it has got a pre-amp then it's possible the pre-amp has failed. To check, remove the wires from the cartridge. And with your finger (with the unit connected to an amp and it switched on) touch the wires one at a time. You should hear a loud buzz on two of the wires. If you do the cartridge is faulty. If you don't the pre-amp has gone. The pre-amp failure will not effect any other function on the amp. Pre-amp's are these days a single IC, which will need to be replaced.
Nov 29, 2015 | Audio Players & Recorders
Does the 3.2 v6 CTS motor have to be pulled out of car to replace freeze PLUGS on block
2003 Cadillac CTS Spark Plug Change 3.2L V6 - YouTube
? 3:08
www.youtube.com/watch?v=8Pzcl-hJ9xQ
May 26, 2011 - Uploaded by Sandman Himself
2003 Cadillac CTS Spark Plug Change 3.2L V6 ... Cadillac CTSIntake Manifold Removal and Valve Cover Gaskets ... CheckEngine Light Flashing? ... CHANGING SPARK PLUGS AND WIRES GM 3.1/3.4 V6 - Duration: ...
Sep 28, 2015 | Cars & Trucks
Need a wire harness plug for a kdc319
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Dec 30, 2012 | Kenwood KDC-319 CD Player
Why do i have a faulty catalytic sonverter on my 2004 mitisubishi galant
Most likely because the engine hasn't run correctly
in years & ruined it
They should last at least 12 to 14 years & still pass inspection.
Jun 17, 2012 | 2003 Mitsubishi Galant
What does the factory set the spark plug gap at?
denso K16TR11 or ngk BKR5EKB-11. Two brands and numbers. the gap is 1.1mm or 0.043in.
May 15, 2010 | 2003 Toyota Tacoma
I am having some troubles in my golf 2003 1600cc SR Engine
Sure -
Go buy the new pre made wires - install them cleanly - if the engine runs better leave them - if not - return them - keep them clean and tidy and no one will care.
Best of it
Mar 27, 2010 | 2003 Volkswagen Golf
2003 Buick Regal Service Engine Soon light.
The error that I'm showing for error code P1133 is
P1133 Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1(Rear Bank).  I would suggest having both of your Oxygen Sensors replaced if you haven't already had that done.  Hope this helps.  Thanks for an honest rating and for using FixYa.
May 19, 2009 | 2003 Buick Regal
Power and fuel mconsumption
If you replaced the plugs, did you replace the plug wires. Even though they are short wires from the coil to the plugs they can go bad. How is the air filter? Have you replaced the fuel filter?
You have four oxygen sensors on your truck. one on each side pre catalytic converter and one after each converter. It is a very pricey replacement because all of the O2 sensors are four wire.
If you change the sensors, your pcm (vehicle computer) will detect the change in readings very quickly. If you really want to ensure the computer completely relearns you need to disconnect the ground for at least 10-30 minutes. When you reconnect the battery the computer will return to its baseline from the factory. It will immediate begin the adaptive learning process to perform in accordance with your driving style.
Another thing to consider is cleaning the mass air flow sensor. This is a very delicate piece of sensor and requires a special cleaner. STP and GUMOUT both sell a specific product for the cleaning of the MAF. Follow the directions. I would be especially concerned if your usinga K & N air filter as the oil from the filter will sometimes coat the MAF and resulting in bad readings.
Good luck.
May 11, 2009 | 2003 GMC Yukon Denali
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
