Question about Toshiba 50HX70 50" Rear Projection Television
Picture & Color Distorted
The picture on the TV is like in 3D with the colors all off and squiggly lines throughout the screen and the sound works. The TV will play for around for around 3-5 minutes then screen goes blank, sound goes off, then the Red Power Button starts flashing. When I put it into Service mode a code of RCUT 30H appears in the left hand corner. I believe there is something wrong with my convergence board. I will add some pictures to show my TV problem in another e-mail...too larger for this website rqmts.
    President:
  • 4,402 Answers
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
The color is distorted and the images on the screen is double.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-65WP55 65" Rear Projection...
I have A 57 inch stand up t.v and it has lost its colorIt is an
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2010 | Philips Magnavox 51MP392H Rear Projection...
Faded and bright
Dull Video...
Convergence
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Colors seem to be out of sync
Dull Video...
Convergence
May 14, 2010 | Philips 55PP9401 55" Rear Projection...
Picture is distorted and jumbled
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 12, 2010 | Hitachi 57F500 57" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Mar 20, 2010 | Hitachi 57F500 57" Rear Projection...
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Televison & Video
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba 50HX70 50" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
