Computer mouse wire loose at mouse - wire connection
  • 3,153 Answers
Although I severely doubt the mouse will give you an electrical shock I would suggest a new one as they are cheaper than a repair would be.
Posted on Sep 12, 2009
Ativa wired mouse was unplugged and when we plugged it back in, it will no longer control our arrow. I tried unplugging and replugging to the laptop but still no arrow. The red light is on, at first it was blinking but no longer. Any help would be appreciated.
Posted on Aug 05, 2011
    Problem Solver:
  • 16 Answers
Buy a newmouse it might give an electrical shock you can also wrap the loose end with electrical tape
I just removed the back cabinet of a Whirlpool Duet Dryer and found a dead mouse where the power cord connects to the cabinet. Machine powers up but doesn't turn. I noticed that the neutral spli
if the wire has a metal end on it and its connected to the white wire, or neutral line, then something is wrong and that should connect to something
Jun 05, 2012 | Whirlpool Dryers
Mouse just quit working. I would like to know how to open it up to see if a connection came loose
If it is a cordless mouse, the battery my need to be replaced, if the batteries are good check your divce connection to the computer.
Feb 10, 2011 | Targus AMU18US Mouse
My mouse keeps loosing connection, ill take out the usb then pluge it back in then 4 secuonds later it will stopworking. please help to fix my problem thanks
first of all check the usb plug in location are they loose using them alot . or change it to another usb port location . it if it is not then the mouse wire would be damaged
Aug 11, 2010 | Cyber Snipa Stinger Mouse
Mouse not working during first boot , if I reboot the system then it is working fine. this means that during cold booting mouse is not working
it may be just due to loose connection of ur mouse wire. better remove the RAM and remove the dust by just rubbing wit eraser and reset it. and aso Check whether your mouse wire is connected properly. Even then the problem is not solved, better give for service
Jul 04, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
I need a wiring diagram for a Targus PAUMO1
Not worth it!
One wrong wire could burn out multiple USB ports on your computer (or any computer the device is plugged into).
It would be best to get a new or used mouse.
Apr 24, 2010 | Targus Ultra Mini Optical Mouse With...
After restart mouse does not work
the only thing you do is restart computer on restart hold down f8 now scroll upto safe mode
and press enter
follow on screen till you are in windows
then restart computer
Sep 19, 2009 | Computers & Internet
The mouse keeps becoming unresponsive and turning off at random
What type of mouse is it? Wireless or wired USB mouse?
If it's wireless, replace the battery with new one or you may try connecting the USB wireless adapter (that came with the mouse) into another USB ports of the computer.
If it's a wired mouse, try connecting it into another USB ports of the computer. Or you may use it with another computer just to isolate the problem. If you would get the same problem even after connecting it into another computer, then I could say that the mouse needs repair.
Hope this helps!
Aug 21, 2009 | Logitech Computers & Internet
Tote n Go laptop, mouse click not recognized
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button: fangletronics.blogspot.com
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
Jun 18, 2009 | Vtech Tote n Go Laptop Plus
Jumping mouse cursor
I think some where in the cable there is a broken wire, it is inside the cable, cause there is a certain position that it work properly. You can also test it by tyring other mouse if the problem still the same.
Oct 16, 2008 | HP Wireless Optical Mouse
My laptop says the usb driver not recognized and keeps beeping, and my mouse works only off and on.
i think there is loose wire connection inside your mouse or wire that connect to your pc from mouse. better change your mouse.
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
307 people viewed this question
David Payne
David Payne
