Question about Toshiba Satellite A105 Notebook
When i turn on power button, laptop starts to power up then shuts off then powers up then off etc but never fully comes on
  • 103 Answers
If you see the windows logo at start up or it goes beyond the laptop start up screen and then it restarts. Then your operating system is corrupted or infected with virus.
please Reinstall or repair your operating system.
Your problem will be resolve.
Please dont forget to RATE my solution
Posted on Sep 12, 2009
How to fix power button
Pam,
The problem is probably not the power button. If you have the AC adapter plugged in but you do not see any lights indicating that there is power reaching the laptop (such as the light that indicates that the battery is charging), chances are that you have a bad motherboard. The other possibility is that you have a broken DC power jack (where the AC adapter plugs into the laptop). Neither the motherboard nor the power jack are user-repairable issues. My advice would be to take this unit to a local professional computer repair center and have it evaluated.
Oct 22, 2014 | Acer Aspire AX1700-U3793A PC Desktop
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
I was working on facebook last night when my screen faded out then at the top of the screen everything started turning an aqua color with minute sized squares similiar to snow and it took over the screen. ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
May 18, 2010 | HP Pavilion dv9000z Notebook
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
Acer labtop won't start...but power light is on
Seems your laptop is overheating.
When it overheats, the laptop shgutsdown as a defense mechanism, to protect important parts like processor.
Check the fans and remove all dust from them with a vacuum..
If that doen;t help, you;ll need to perofrm a deeper cleaning of the heat sink and apply a fresh heat transfer compuond at the CPU.
You mention you have your laptop since 2006.
I would say its about time for a deep clean up
Please don't forget to rate this answer if you find it helpful
Thank you
Jun 25, 2009 | D-Link DU 520 (DU-520) Serial Adapter
ACER Aspire 5570z won't start
Check your memory card, reseat or clean it with soft eraser its edge connector. But first shut it down fully, battery disconnected and no other power source connected to it before doing so.
If this does not come on test with a spare ram. Before checking on another fault.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
MY LAPTOP WILL NOT TURN ON
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
If this doesnt work can you hear any fans or hard disk activity when you press the power button?
Jan 20, 2009 | Toshiba Satellite M35X-S349 Notebook
Sony laptop
You probably have the "go to sleep" timeout set too low. Check out "Power Options" in the control panel.
Mar 05, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
