Question about Kenmore 24032\24036 Top Load Washer
80 Series Top Load\ Water Feed
Kenmore 80 Series Top Load Water feeds very slowly. Recently had a plumbing issue with a faucet and got the wll water tank stirred up. I had to clean out the aerator filter on two faucets.
Is there a screen to clean out on this washer? If so, how do I aceess? If no, what could the problem be?
    President:
  • 1,653 Answers
There may be a screen in the inlet pipe where it joins the back of the machine. Also check that the inlet pipe is clear and running water correctly before connecting it back on the machine. If this is OK you may have an issue with the inlet valve not opening fully. This is quite a common issue and will need the inlet valve repalcing.
Posted on Sep 12, 2009
My Whirlpool Front Load washing machine "sings" during addition of water during some portions of the cycle. In other words, when adding water to the machine, a high-pitched sound is produced...
The chances are that this is one of the rubbers in the inley valve vibrating at a high frequency as water rushes past it. Usually the result of high water pressure, though occasionally low pressure (But I would expect you to describe that as a low humm, so lets presume the pressure is a bit high).
Your machine may be cold fill only or hot AND cold fill. The chances are highest that the COLD feed is the issue (Hot water is usually at a lower pressure) so start there.
Try reducing the pressure to the feed, if you have no specific way of doing this, then simply go to the isolator valve where the feed pipe to the machine meets the plumbing and slowly turn it off. as you turn the lever on the valve, the noise will probably reduce long before you have actually isolated the water supply completely. Leave the isolator valve lever in that position.
Jul 19, 2011 | Washing Machines
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Mar 19, 2009 | Culligan Under Sink Water Filter
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
American Standard kitchen fawcett
It could be air if you recently had the water off at the main and let the pipes drain, but this would go away after a short while. It is most likely either a feed line from the wall to the faucet flexing when the pressure and hitting something under the sink or a water line in the wall that may have not been strapped properly to the stud when installed. They bounce around sometimes if not secured. Hopefully the feed line as the second is a bit more work to correct.
Good Luck
Nov 29, 2008 | Plumbing
Kenmore 80 series
suspect sand/rust has gotten past screens inside water valve or screens are missing allowing residue to get into valve ..replace valve ..clean screens as needed in future but be sure to reinstall
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
143 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
