Question about Toshiba 51HC85 Camcorder
Can i charge the camcorder using a usb cable - Toshiba 51HC85 Camcorder
  • 10,594 Answers
It depends on specifications of camcorder, few can be charged with USB and many can not.
Please check camcorder manual or supplied documents for charging battery.
Thanks.
Posted on Sep 12, 2009
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My camcorder won't charge, should I just replace the batteries or is it rechargeable because I found a USB cable, is it for charging? Or for transferring videos to a computer or laptop?
The USB cable is not for charging, only for transferring. If you want to use rechargeable batteries then you must recharge them using a separate battery charger.
Jul 03, 2013 | Cobra 5MP, 8x Digital Zoom Camcorder w/...
Camcorder hrdpj10 wont charge via usb
Hello you can download the manual here:
http://esupport.sony.com/US/p/model-home.pl?mdl=HDRPJ10&template_id=1&region_id=1&tab=manuals#/manualsTab
The camera does not charge via usb.
You have to connect the power supply to charge up the camera:
Good luck
Dec 26, 2012 | Sony Handycam HDR-PJ10 Camcorder
How can i charge my Jazz Hdv188 if i lost the charger?
You can use any generic micro-usb to usb cable and charge through your computer. I lost my stock charger and had a micro-usb from another camera
Mar 13, 2011 | Jazz HDV-188 Camcorder
Jazz camera bought from the U.S.. Once we changed the adapter to charge the battery in Europe, including the charger in the network signal and does not want to work
you should be able to charge the battery using a usb cable from your computer. see photo for type of usb cable you need. this cable should have come with the camera.
Hope this helps!
Tom
Mar 02, 2011 | Jazz HDV-188 Camcorder
How can I charge my dcr-sr47 camcorder with a usb cable and my pc?
You may not be able to.
Most cameras require a stand alone charger for battery charging.
Some models will allow in camera charging via a connecting dock or purpose builtl power cable.
Your camera manual should advise .
Feb 04, 2011 | Sony DCR-SR47 Camcorder
Can I use a usb cable to charge my jvc everio camcorder
As long as you have a USB port and there is 4 AA or AAA batteries then you should be able to. USB is 5 volts DC and 4 batteries are 1.2 volts each and 4 equal 4.8 volts DC.
Nov 01, 2010 | JVC Everio GZ-MG360 HDD Camcorder
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 | Cameras
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
351 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
JonSnell Electronic
JonSnell Electronic
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
