Question about Dell A940 All-In-One InkJet Printer
The printer is on, the pc is communicating with it, the cartridges are full, the pages come out blank. What gives?
Wiired
  • 122 Answers
SOURCE: page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Posted on Jun 23, 2009
  • 71 Answers
SOURCE: The printer is printing blank pages.
STEP 1: Disconnect and Reconnect the Printer Power Supply
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
STEP 2: Run a nozzle clean on the Dell A940 inkjet printer.
To run a nozzle clean, perform the following steps:
1. Click the Start button, point to All Programs, point to Dell Printers, point to Dell AIO Printer A940, and then click Dell Printer Solution Center.
The Dell Printer Solution Center menu appears.
2. Click the Maintenance button.
The Maintenance window appears.
3. Click the Clean to fix horizontal streaks button.
4. Click the Print button.
The Nozzle Clean function prints a page.
5. Check the Nozzle Clean Printout to verify that it is free of defects and that all expected color bars exist on the page
STEP 3: Restore the printer settings to factory default
To restore the printer settings to factory default, perform the following steps:
1. Click the Start button, and then click Control Panel.
2. Click Printers and Other Hardware.
3. Click Printers and Faxes.
4. Right-click the Dell Printer icon, and then left-click Properties.
5. Click Printing Preferences.
6. Click to select Save Settings.
7. Under Restore, click Factory Settings (Defaults).
STEP 4: Clean the Contacts and Wick the Ink Cartridge
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
1. Ensure the printer is powered on.
2. Lift the scanner unit.
3. Open the cartridge latches and remove the cartridges from the carrier.
4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
Cleaning the Contacts
1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
2. Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible.
Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
4. Replace the cartridges in the carrier and close the scanner unit.
5. Print the document again.
6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Then run again STEP 2. If the printer still prints in blank pages, contact Dell Technical Support. They may need to replace the Ink Cartridges.
Posted on Jul 02, 2009
T3KK
  • 171 Answers
SOURCE: prints blank
I know this may sound silly - but on th ebottom of the new cartridges there are little plastic slips which need to be removed before using... make sure these have been removed.
If this helped you then please help me and vote kindly.
Posted on Oct 15, 2009
  • 20 Answers
SOURCE: New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Posted on Dec 17, 2009
  • 31 Answers
SOURCE: thougth printer cartridge was empty, printing
Most toner cartridges have a pull tab on them to open the flow of the toner. Maybe you didn't pull this tab. Also most machines want you to perform an alignment process for the new cartridge and if you haven't done this it will sometimes cause the printr not to print correctly.
The old printer cartridge may have been so low on ink that it did not print properly.
Posted on Sep 21, 2010
Printing blank pages ipf6300
Hello, can you give me more details? The ink cartridges have ink, if not replace with new ones? Is the print head expired, replace it. Take note: if you hwant to replace the printhead your cartridges need to be al 90% full.
Feb 11, 2014 | Canon imagePROGRAF iPF6300 Large Format...
Options:
1: the cartridges have run out. They are quite small and will give 40 to 50 pages of text or 10 to 15 pages with colour. You might be lucky to get a couple of photos of a full set of cartridges. Take them out and feel the weight - if they feel really light they will be empty.
2: the print head has dried out. Take it out of the printer, wash it in warm water (just water) and dry it with a paper kitchen towel. Replace it and try again.
Jan 29, 2014 | Canon PIXMA iP90v Printer
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Nov 10, 2012 | HP PhotoSmart 7760 InkJet Printer
My lexmark is connected to my pc, my ink is more or less full it is making all the right noises for printing but the paper comes out blank...........please help its a lexmark 12
Try to re-seat your ink cartridges by removing it from the printer. Then unplug and replug your printer into the power source to reset. When the printer turns on, reinsert your cartridges and make sure they're properly secured. Let it print an alignment page. Or try to print again. If still nothing is printed, your cartridge nozzles may need some cleaning. This article in the Lexmark website will give you steps on how clean the cartridge nozzles: How to Maintain the Print Cartridges on the Lexmark All-In-One Printers
Apr 18, 2011 | Lexmark X2670 All-In-One Printer
My HP Photosmart printer was printing just fine until I had to change ink cartridges. Now it won't print anything, it just spits out a blank page.
Sometimes your printer print blanks pages, if your printer is out of ink. You can check the quantity of ink in the status of the printer. Sometimes, your printer displays messages if it is out of ink. So if you are facing such issues, you need to refill the ink in your printer. Communication problem with the printer and computer is also a reason for printing blank pages.
Jan 03, 2011 | Office Equipment & Supplies
My printer is printing blank pages. The test print prints all the colors though. But when I print a document all I get is a blank page. I just installed a new color cartridge.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 09, 2010 | Canon PIXMA MP470 All-in-One Printer
Page blank when printed
Jun 23, 2009 | Dell Inkjet 720 Printer
Cannon S200Spx prints blank pages
The problem is likely to come from your printer settings in your printer properties dialog box. Right-click the printer icon and select Properties. You will see within the dialog where to set the printer to print on black only and then appropriate. restart your pc and then try sending to printer again. Good luck
Jun 03, 2009 | Canon S200X Ink-Jet InkJet Printer
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
