Question about Poulan ES350 16" Chain Saw
How to repalce start pulley on Poulin chain saw?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
First of all the fan housing needs to be removed. No need to remove handle from cord. Just undo screws from fan housing and remove the whole assembly. Inside you will see the pulley. Different models have different set ups but they are all basically the same. A screw should be holding a hub that is holding the pulley. Some models have a ring that holds the pulley onto the fan housing. Before you remove the pulley you need to unwind the spring to be safe. Otherwise it will spring out on you. To do this pull about 6" - 12" of the cord out. There should be a slot in the pulley that you can push the cord into. Hold the pulley and fish the cord into this slot on the pulley. This way you can unwind the spring. Once the load is off the spring you can remove the pulley. Remove the starter cord retaining screw and remove cord. Replace cord on new pulley with retaining screw. Sit the cord into the slot mention previously on the side of the pulley. Line up the slot on the spring side of the pulley and push the pulley down onto the spring. Some pulleys have tight tolernaces and you will have to tighten the spring by turning the pulley before it will seat. Once you can seat the pulley re-install the retainer. Keep the cord in the slot on the side of the pulley and turn it making sure you are tightening spring. When you think you have enough tension on the spring undo the cord from the pulley and see how it works. If it there is still too much slack repeat the process of putting the cord in the pulley slot and tightening a little more. After you have the correct tension on the pulley you can replace the fan housing onto the saw. As you are putting it back on pull the cord slightly to line up the starter with the fan.
Posted on Sep 12, 2009
Is the main chain drive shaft available for the 42cc Poulin chain saw
Parts should be available for most models, you will need to get the correct model number to find out if it is available and wheather it is a viable repair,
Jul 06, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
I need a schematic drawing for a Poulan 445 PRO Chain Pole Saw
Go to this page:
http://www.jackssmallengines.com/help.cfm
Choose
1. Poulin
2. Poulin Pro
3. Pole Pruner
4. Gas
Then select either PP446E Type 1 or Type 2
If you need parts for the attachments then choose attachments and find yours.
This will get you straight to the engine:
http://www.jackssmallengines.com/help.cfm#AssemblyPartsSearch'model_3hfQcmydHGxAIk/GvlHpyA=='assembly_/GhQJfqNUvNbNmAjA03NAg=='brand_ahjxOQtsOoMBNqd6InjYkA==
Thanks for choosing FixYa.
Kelly
952-051549
Oct 02, 2010 | Garden
I have a Poulin Pro 46cc he problem I'm having is with the brake. How can I adjust it to stop the chain.
The likely problem is that the 'toggle' mechanism for the brake is plugged with dirt/sawdust and won't allow full travel of the brake. Try compressed air to clean it out. The brake band could also have excessive oil on it--wipe it clean along with the clutch outer drum surface. Hope this helps!
Sep 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Installing recoil spring for Poulin P3314
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I need a drive sprocket for the chain on my poulin es350 chain saw
I checked Poulans website and they dont show a breakdown for this tool, but you can call 1-800-554-6723 and request assistance
Mar 02, 2009 | Poulan ES350 16" Chain Saw
My poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Feb 23, 2009 | Poulan Garden
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan ES350 16" Chain Saw Logo
162 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
