Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
How do i light a Reddy Heater rcp 2000 lp gas heater?
  • 55 Answers
Hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Posted on Sep 13, 2009
Have an rlp30 reddy heater, have spark and gas but will not light.
wile red button is pushed no flame or turns off when the button is released the flame dies ? if no flame tank is too small or spark isn't in far enough to catch gas . if flame is present with button down then the over heat switch on the in line thermal coupler could b bad u can check the over heat switch with a jumper between the two wires and if it stays lit you got it if it goes out then its the thermal coupler that's bad
Dec 12, 2013 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
I have an empire corcho model 15-1. It will not light with the ignition button what are the possible problems? LP gas is to the unit.
ignition out of postion , it needs cleaning , end of ignition brunt off or too short, blocked pilot, ignition shorting out on heater causing short spark
Nov 28, 2010 | Reddy Heater RLP100 Portable Forced Air...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I have the pro reddy 100 LP. It hasn't been run
replace the thermocouple anyway,it will go bad after time
Dec 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
217 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
