Question about Dryers
Fails to turn off, and now no heat.
I have a Kenmore 73742 gas dryer. Last week, it began failing to turn itself off - by sensor or timed dry. Yesterday, it began failing to ignite the burner - therefore no heat. Push to start switch works. It turns off when I open the door and I can hear the timer running when I manually activate the door safety switch with the door open.
Which part(s) need to be replaced? Timer, thermostat(s), ignitor? Other?
  • 986 Answers
Runs and never stops:
In all probability this may well be the timer motor has quit,and thus the timer needs replacing right? Maybe, but you need to first check to see if your dryer has a moisture sensing system, If the sensor board contacts get corroded or goes caput, then the dryer wont know when to advance and shut off in newer models!
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Kenmore 80 Series Gas Dryer... fails to ignite, even tho it fired up when I replaced the white sensor in the filter-side exit, which was said to be the likeliest culprit. When I had the back-panel off, it...
Here are a couple of tips about dryers not heating....................... if your dryer is electric go check out this electric no heat tip...
and if you dryer is gas check out this gas no heat tip....
heatman101
Aug 27, 2010 | Kenmore Dryers
Dryer heats to proper drying temperature and then temperature is not maintained and drops off causing long drying time when on timed drying...GE Medallion 850 - bottom heat sensor was cleaned.
you didn't mention if dryer was gas or electric. gas dryer could have bad valve coils which will work for a short time and then fail, cool off and then work again and fail, causing intermittant heat.
May 05, 2010 | Dryers
My gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
Feb 22, 2010 | Whirlpool LGB6300 Gas Dryer
Kenmore Elite HE3 Gas Dryer no heat
Verify the glow bar ignitor is working. Also ohm it to specs before you replace a gas valve coil.
Mar 02, 2009 | Kenmore Dryers
Dryer heats timer advances however won't shut off
Timer replacement needed unless you can deal with it.
Jan 20, 2009 | Dryers
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
