Question about Craftsman Garden
I have no spark, but dont know the part # to order it
  • 124 Answers
Contact southern supply
company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you. Give them the sears model number and they can supply you with the correct part.
Posted on Sep 14, 2009
Installing Spark plug wires
Unless the wires were removed the firing order cannot change as also the length of the wires do not permit that the wires switch over.
All what is needed is to check the spark at each plug , if of low internsity check the ignition system including the HT coil. Also the fuel filter and the fuel pump for the right pressure.
Nov 22, 2011 | 1996 Honda Accord
2000 olds alero v6 spark plug firing order diagram
2000 Oldsmobile Alero 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
Jul 05, 2010 | 2000 Oldsmobile Alero
I dont know in what order my spark plug wires hooked up.
Chec here the MUSTANG FIRING ORDER
Below are the firing orders for 5.0L, 4.6L, 3.8L, and 2.3L late model Mustangs. Remember to be very careful when checking your firing order because the ignition system on your car runs on very high voltage. Do not remove spark plug wires from the distributor or spark plugs while the engine is running.
Firing order sequences:
V8's 1-3-7-2-6-5-4-8
V6's 1-4-2-5-3-6
2.3L 1-3-4-2
Hope this help (remember comment and rated this) TY for using Fixya.
Apr 30, 2010 | 2005 Ford Mustang
Firing order range rover 40ltr v8 p38
Passenger side front to rear 2,4,6,8, driver side 1,3,5,7. Distributer rotates clockwise. Number 1 is usually marked on the cap.
firing_order-1.jpg Leads for distributor cap should be connected as illustrated.
RH - Right Hand side of engine, when viewed from rear.
LH - Left Hand side of engine, when viewed from rear.
Feb 06, 2010 | 1995 Land Rover Range Rover
Have 1988 pontiac grand prix se with 2.8 v6
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered question.
For the 2.8L
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)
1.......3.......5
2.......4.......6
......(front)
Ignition Connections (Spark Coils):
........(back)
.|.1..4.|.|.6..3.|.|.2..5.|
........(front)
Again my apologies....
Let me know if this helped...
Jan 22, 2010 | 1988 Pontiac Grand Prix
My 93 honda prelude dont start i did a full overhaul but i can get it to start timing is right so i dont know wat to do next
Timing is right, but the firing order is incorrect then it could not start. Make sure connection at the spark plug is in the firing order. Let get back to the basic: need spark and fuel. After several cranking, take plug # 1 out to see if it wet. If it is wet then you have fuel. If it is dry then you don't have fuel. Start to find out what is the root cause for fuel not coming. Now touch the spark plug to the engine chassis and have a helper to start engine. If there is spark strong then you have spark. If no spark then you know what to do: find the root cause of the problem. If you have spark and fuel then need to recheck timing by Top Dead Center: Piston #1 is up, mark at camshaft and 0 mark at crankshaft all line up together while intake and exhaust valve closed. Good luck.
Nov 10, 2009 | 1993 Honda Prelude
The fuel injectors
the first thing you should check if your car doesnt start is compression, then ignition, then fuel, in that order, even if you got spark and fuel without compression your going no where
Mar 24, 2009 | 1992 GMC Jimmy
Backfire through intake
 Check compression possible tight valve lash, if ok Check for vacume leak, make sure firing order is correct, check power to injectors an make sure injectors are working.
Nov 29, 2008 | 1992 Honda Accord
Ihave changed the spark plugs but i dont know if put the caps in
Not sure what you're asking. The only order that matters is the order of the spark plug wires. There isn't an order for the spark plugs themselves. So are u looking for the order of the spark plug wires?
Nov 12, 2008 | Honda Civic Cars & Trucks
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
