Question about Garden
My countax ride on lawnmower has no life in it when i turn key. i had battery charged fully but it made no difference
  • john_naughto Sep 12, 2009
    i tried dis engaging the clutch...didn't work
  • 3,037 Answers
Have you tried a different battery (such as a car battery)? Or have you tried jumping the lawnmower to see if the battery is just shot. If you take the battery into a lawnmower dealer, they can test it for you to eliminate whether or not it is the problem or whether you have a wiring problem. Let me know what you find.
Benjamin
Posted on Sep 12, 2009
    Brigadier General:
  • 4,090 Answers
Have you disengaged the Clutch and locked it down? Push clutch to floor and either engage the holder toggle or keep it there with your foot whilst turning the ignition to Start.
Other than that use some jumper cables from battery directly to starter motor, if it turns and starts , then you have a wiring problem. But my bet is that you have not disengaged the clutch drive.
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
My countax 300 will not start there is nothing wrong with the battery
First check the safety switch under seat is working by bridging the gap.
Try the same with the safety switch on hand brake.
Check fuse hasn't blown.
Check spark plug is intact and cable is correctly fitted.
Check in line fuel filter.
Ensure battery is fully charged, a drop in output will result in not starting.
Hope this resolves the problem.
Gareth
Aug 02, 2013 | Yard Machines Garden
I have a lawn flight 12.5 briggs and stratton ride on mower and when i turn the key all you can hear is a single click coming from the engin area. ( cutters are up, brake engaged, oil topped up so no cut...
Check and make sure your battery is fully charged, if is is ok then you need to do the following.
Check/Replace your starter solinoid.
Normally they will be the problem when you hear just a click.
Free answer...Please rate me
Apr 10, 2011 | Briggs & Stratton Briggs Stratton...
Engine starting problem
The battery still may be bad. The fact that it "warmed slightly when being charged" doesn't suggest it to be good - instead it could have high internal resistance in one or more cells. A battery with this failure still measures a good 12V until you put a load on it. I'd take the battery to a battery store, not a lawnmower dealer, and have it tested there with an actual battery tester. If it's bad, replace it. If it's good, then it's probably the solenoid and that means you'll have to replace the starter/solenoid assembly.
Jul 05, 2010 | Garden
Rally ride on lawn mower not starting. briggs and stratton 12 hp engine. battery fully charged but engine not turning when ignition key turned
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
May 03, 2010 | Garden
The sweeper shaft on my countax lawnmower keeps pulling to the left and falling out out the bearing on the right anyone know how to fix this
I have a countax E36 which had the same problem. If you remove the axle of the sweeper you will most likely find the square axle damaged at the end. I ordered a new one from cyriljohnston.co.uk and had it over night €28.00 all in. When replacing it, you may need to install washers to take up the wear on the bearing eyes ! Hope it works for you
Apr 29, 2010 | Garden
My lawnmower won't start. WHen I turn the key it
Check battery cable for correct hook up. Red positive to starter and black to ground. If battery connected backward starter rotates in opposite direction and can burn up starter. If correct battery hook up check plastice gear on starter for wear.
Mar 11, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have an htc ozone, what is the proper way to charge it for maximum battery life? seems to drain out shortly after an all night full charge. Thanks.
I just got my Ozone a few days ago. What you should always do with an electronic device is charge it fully before turning it on. Then using it until it dies completely with no battery. Then fully charge it again for maximum battery life.
You can go to Start, Settings, More, Power, Power Management. Change the different things to make it save on power. Also a big help is Start, System tools, Task Manager and delete everything that is being used. That just turns it off in the background, it doesn't delete the program.
Aug 31, 2009 | HTC Touch P3450 Smartphone
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
