Question about Canon MX300 Office All-In-One Printer
Have canon MX300 All in One have had printer cartridges refilled professionally, worked few times now the alarm light is on and when try to print comes up with ink cartridges cannot be recognized. Tried to scan and comes up with Printer Maintenance is in progress. Scan after it is complete...
Canon Pixma MX300 won't print black anymore! How to fix?
I have used "refill" kits in the past and for the time and effort involved you might just try finding a local retailer that will give you credit for the empty cartridge to replace with a professionally refilled one.
The problem with refilling the same cartridge over and over again is that they will, eventually, need to be replaced. I would suggest that you
1 - Make sure there is nothing plugging the hole at the top of the cartridge to allow air in, which is needed to let the ink flow out.
2- Install another cartridge and you get the same problem, then it narrows your fix to something with the printer.
3 - If it is the printer, I were rubber gloves and use "denatured alcohol" and a rag (no not use anything with paper as it can tear and leave pieces inside causing the printer to jamb) and after removing all of the cartridges wipe down anything that I can reach inside the printer.
4 - Although you have tried the DEEP CLEAN, if the none of the above works for you, try the NOZZLE CLEAN. If you are still having a problem then either re-post the problem or doe a Google Search listing the model of the printer you have, you may find out it is a problem that others have experienced and there is no solution.
Good Luck
Apr 06, 2013 | Canon PIXMA MX300 All-in-One Printer
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
PIXMA MP210 Photo All-In-One Printer: Alarm light is on and I have just refilled my cart...
Hello!
I work in a refill shop, and we have noticed that after refilling cartridges for Pixma MP210, they won't work.
Try holding the "resume" button (triangle in circle), for about 10 sec. for each cartridge- that should reset the cartridges (and usually it works with every Pixma printer, but almost never with the MP210, I really don't know why)
If that doesn't help, you should buy new cartridges.
May 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
I just refilled my black ink cartridge in my mx300 canon printer, but it still says out of black ink, I think because the cartridge has been a little overfilled. when I click on supply levels it says...
You will have to purchase a new cartridge as your printer has a mechanism built-in which detects the date of the cartridge and locks it if it was once empty and then re-filled.
You can try and ask the re-fill vendor to reset the cartridge time but not every cartridge can be initialized.
Sep 15, 2009 | Canon PIXMA MX300 All-in-One Printer
Alarm light is on. does not print
Those cartridges can't be reset yet, once they are empty, the little circuit board says they are used up and you have to replace them.
Aug 12, 2009 | Canon MX300 Office All-In-One Printer
MX300 alarm
You might try a hard reset of printer along with uninstalling and reinstalling the software for the printer.
If nada, you might give Canon a call and ask their techies for their feedback on situation.
Jun 19, 2017 | Canon MX300 Office All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
116 people viewed this question
old marine
old marine
