Question about HP Pavilion dv4000 Notebook
Replacement part
Hp dv4000 pavillion looking for part number for laptop upper lid that is cracked fro opening and closing
  • 2 more comments
  • Manta Ray Dec 29, 2007
    same problem. is the gray external portion of the lid replaceable or does the entire lid need to be replaced? where can I order or get repaired?
  • Anonymous Jan 10, 2008
    Cracked lid arond hindges.
  • djbj Nov 12, 2008
    I have the same problem. Wondering how the original person posting this made out and if it was worth fixing it or not.
  • mabiemadboy Jan 15, 2009
    Mine too, but im not sure where to go
  • 1,601 Answers
Page 57 of this manual can tell you your part number.Let me know how you make out.
Posted on Dec 11, 2007
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
How to remove battery on motherboard on hp pavillion dv4000
which bettery u wnat remove
if u looking to remove cimos bettery then in this model you have to open from the keybord penal if you well noon in this then only
or go to technition
May 15, 2010 | HP Pavilion dv4000 Notebook
Screen will not come on hp pavillion 2000 laptop help
try powering the laptop on, and open/closing the lid.
this is to ensure, the closed lid catch is activating/de-activating.
you should get a beep or tone, when the lid is closed.
Or the laptop, will go into Sleep/hibernation Mode.
Also try pressing and holding the power on Button for more Than 5 seconds, This will eliminate that the laptop hasn,t gone Into sleep/hibernate Mode.
If none of this Works for You. Try removing and replacing The memory modules ( RAM ) and use 1 stick of memory in each slot individually. failing any of this. i,d suspect. Screen Inverter/tft Panel Or Motherboard Fault. Or possible graphics driver Corrupt/missing.
Mike @ Compurepair.
Oct 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp dv4000 screen problem
Sounds like its trying to go into sleep mode or standby or just turning the screen off.
This usualy happens because in the power options, the screen is set to shut off after say 5 minutes. It could be that the lid closed sensor is bad and it thinks your closing it and does this.
Try right clicking on the desktop, select properties, in the pop up box, select the scren savers Tab and at the bottom it should have a button for the power options.
Click that, in there you should see several new tabs partaining to your power options. one has some drop down boxes that lets you set what it does when the lid is close, when you press the power button and when you press the sleep button.
I would try turning the, " turn off screen option" to off and see if it still does it.
It usually says. 'When I close the lid to my laptop, i want it to: " then it will list the options.
Also turn off the standby settings if you want so it doesnt go into standby every time you walk away for 5 minutes.
Just set it how you want. but for now, just disable the close lid options so we can see if it still does it.
Good luck and let me know.
Jan 07, 2009 | HP Pavilion dv4000 Notebook
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
Hp pavillion dv4040 us problem with monitor ''button''
ok go into control panel.double click display properties click on screensaver;then click on power options properties select never in all the fields.then click advanced and select options in power buttons.e.g. when i close the lid on my laptop select do nothing.same for sleep button(hybernate)...
Nov 23, 2008 | HP Pavilion dv4000 Notebook
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
