Question about Sharp Microwave Ovens
I just need to purchase the correct light bulb for a sharp R-1420B over the range microwave
  • Sharp Master
  • 9,047 Answers
The Sharp part number for the oven lamp is RLMPT0003YBE0 (those are "zeroes", not "ohs").
Maybe the generic # is EHKN-122?
You can order the original from Encompass here or you can call them toll-free at 866-779-5835.
Bulbs (and 20A ceramic fuses when needed) can be had locally in most grocery stores, hardware stores, home improvement centers (Lowe's, Home Depot, Builders Square), and big box or department stores like Wal-Mart.
Just take the old one and match it up.
Always unplug a microwave before removing or installing any bulbs.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
Looking for 50 watt halogen bulb wb36x10213 for the microwave over the range
take the old bulb out and go to the hardware shop or the 1 pound shop
its a standard size
Aug 12, 2014 | GE Microwave Ovens
Sharp carousel R1472A Over the range microwave. Night light on microwave that shines down on range top will not work, Help! Yes, has two new bulbs.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Yours is similar to this one:
Apr 25, 2011 | Sharp Microwave Ovens
We're trying to remove our sharp R-1420B microwave oven off the wall. We're having absolutely no luck. How do we get this off the wall?
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
May 16, 2010 | Microwave Ovens
Work light switch not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes or you can see the service manual at our site here.
William E. Miller
prototech@usa.net
May 13, 2010 | Sharp R-1601 Microwave Oven
Sharp Carousel Microwave work light/night light has two light bulbs. One light will turn off by pressing the panel control, but the other light remains on. Must remove light from socket in order for the...
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
Jan 29, 2010 | Sharp R-1610 Microwave Oven
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Dec 27, 2009 | Sharp Microwave Ovens
Sharp carousel non functional overhead light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 31, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
