Question about Refrigerators
My tek 2 bloes fuses on dc, works fine on ac.
  • Mike B Foster
    Mike B Foster Sep 12, 2009
    This is not a brand new Tek 2 cooler/freezer. It's been working fine, but now blows fuse on DC but works fine on AC
  • Mike B Foster
    This is the information I needed. Thank you
  • Refrigerators Master
  • 19,396 Answers
The fridge inverter is faulty and must be replaced. The inverter board converts DC voltage into AC to supply power to compressor motor.
The Company will provide free servic
e and replacement of defective parts. Call the phone number listed on the owner manual to get replacement. In US call 1-800-543-1219.
TEK II DUAL VOLTAGE REFRIGERATOR OWNER'S GUIDE
Posted on Sep 12, 2009
    President:
  • 2,004 Answers
This is a manufacturer defect.
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
Wont turn on
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 25, 2011 | Gateway MD2614u Notebook
Acer 4620 is dead
Aug 25, 2011 | Acer Extensa 4620 Notebook
But its not chargin when i plug it in and i dont how to fix a DC jack..
May 24, 2011 | Computers & Internet
Battery light is blinking red and will not charge
Welcome to Fixya! If the battery light is blinking red,that indicates low power, there's a possibility that the problem is with the AC adapter, or the battery or maybe the DC port itself, please follow these simple steps for you to be able to isolate the exact problem.
Feb 28, 2011 | Panasonic Toughbook CF-73 Notebook
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
TV/DVD COMBO WON,T WORK ON DC WILL WORK ON AC
Have you checked the fuse in the plug on the end of the DC power cord? Just unscrew the end.
Dec 30, 2008 | Sansui CDVD9000
Won't work on ac
1. Make sure the AC power source is ok.
2. Make sure the AC power cord is good with no damage.
3. Look to see if there is a reset button on the rear of the set. If not, then look for a blown AC fuse inside the set.
Since the set works fine on +12VDC, the majority of the TV set is ok. You have a problem in the AC power supply. It could be a blown fuse, bad rectifier / regulator, bad step-down transformer.
The TV typically runs from +12VDC. The AC supply steps-down the 120VAC and rectifies it into +12VDC to power the TV. At some point in the TV, there is junction point where the +12VDC from the sets internal AC supply meets the external +12VDC power source. Usually they are electrically isolated from each other with a switch or with diodes.
Please let me know if I can be of further assistance to you.
- Jim
Mar 04, 2008 | RCA E13335GY TV
Toshiba 9" TV/VCR W/CAR AC/DC - No power when on battery
I would check on the inside for a disconnected wire or loose connection at the Dc imput if it still works on ac. You can most likely get a service manual at http://www.servicemanuals.net/ if the wires are intact on the DC imput and the jack itself fits secure to the adapter. Hope this helps
Oct 24, 2007 | Toshiba 9" TV/VCR W/CAR AC/DC COMBO...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
