Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
The compressure clicks but don t cut off every time
  • 525 Answers
Check the relay and the compressor if you know how to check them .if not, call a technician.
Posted on Sep 12, 2009
Won't run
It sounds like the common line (white wire) may be broken or disconnected in the line going to the recepticle. When this happens the missing common line is somewhat created down the line through another device or appliance plugged into the same line. It would take too much typing time to explain how this happens but you should call in an electrician to test the circuit for you if you don't have the experience to do it yourself. If you plug in another device like a heater etc (like Jay suggested) and it barely runs, that is a good indicator of a bad common line. Don't continue to try using this line as you will burn out the compressor.
Dec 27, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My alternator went out i replace it now the a/c compressure and cooling will not work,i replace the relays steel don;t work
look where you were working and you may have knocked off a pressure control plug on ac.
Aug 10, 2011 | Heating & Cooling
2008 honda pilot a/c is not blowing cold air, blows hot air. bought truck in 2007.
the most common problem with honda and acura is the magnetic clutch failure on the compressor , test to see if you are getting power to the clutch assembly with the car runningand the A/C on max if you have power the compressure clutch is bad if you don't ck the compressure fuse and or the clutch relay.
May 05, 2011 | 2008 Honda Pilot
How to calculate cfm of air compressure . we have required one air compressure having 7bar-10 bar pressure how much cfm it will have
If you are still looking for an answer to this question, here is a website that will explain how to calculate CFM of an air compressor...
http://www.ehow.com/how_5001852_calculate-cfm-air-compressor.html
Jun 26, 2010 | Atlas Copco LS 16 Hydraulic Cut-Off Saw...
(8 Bravda old. air condion inoperative Freon
how do you know freon is ok it sounds like it is low and the low pressure switch is cutting compressor off and back on
Mar 24, 2010 | 1998 Oldsmobile Bravada
My 02 sonata a/c system doesnt blow cold?
Ok... you wrote "lock was all dry but after i charge the system it start leaking from the same place that the original was leaking,(center of ac compressure.)" Sounds like you should have 'OVER HAULED' the existing/used compressor before installing it... OR bought a recondition/new compressor (ya think?). It appears both the original and used compressors have the same defect.
Jun 24, 2009 | 2000 Hyundai Sonata
Freezer freezes but fridge does not get cool
DO u have frost build up in the freezer ? If so you have a defrost problem.. defrost thermostat, timmer or heaters. You can by-pass the thermostat cut it and tape the wire together and put it into defrost with the timmer by clicking it to the right until it clicks the heater you need to ohm out .. the defrost timmer will be good most of the time if it comes out of defrost ... ref. will start running again when u test the defrost thermostat here is a diagram that may help
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00011&componentDescription=AIR%20FLOW%20AND%20CONTROL%20PARTS&documentId=00016472&modelNumber=1068562782&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
Aug 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Rooftop unit economizer not responding. I tried to simulate hot ambient temperature, but compressor did not kick in, check the resistance of OAT sensor and it's good.
1.check spare parts of compressure.
2 check wireing of compressure.
3. check voltage.
4.check continuti of compressure.
5. check discharge pressure.
Apr 04, 2008 | Heating & Cooling
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
