Question about Refrigerators
I have a GE GTH22KBRARWW refrigerator/freezer. The freezer has stopped working. I have pulled the back panel off of the freezer, and the chilling unit is free of frost. The condensate drain is completely clear. The fan works fine, but the cooler unit just doesn't seem to get cold. All of our frozen goods are defrosted. The unit does not have an ice maker. I've been given some tips to check the defrost timer and the thermostat, but I need advice on how to find these and test them. Can enyone help?
  • 2 more comments
  • john_carr118 Sep 12, 2009
    Where's is this thermostat mounted? The controls for the settings are in the fridge compartment, but that daial is attached to a small circuit board. I assume that the thermostat must be somewhere in the freezer compartment, but any hints on its location would be appreciated.
    Here's a bit of good news though. I live on an island, but my wife is in town and has managed to find the part at a local supplier, so I should be able to install it later this afternoon.
    I think I can see the thermostat. Is it on the right side, clipped to the back of the cooling line? It looks like it accessible only from the back of the unit. There's an access panel there. Is that the right thing?
    Yes, that's what I've got. Any tips on where it's mounted? I see something that may look like that, but it's mounted on the back side of coolant line in the freezer compartment. It looks like it will be pretty hard to get to without unscrewing the coil from the back of the unit, and I'm reluctant to do that for fear of breaking a seal in the lines.
    John C.
    The fans are running, and the compressor seems to be running some of the time (it's hard to tell without pulling the whole fridge out from the wall), but it's not cooling down. Does that still sound like the thermostat?
    John C.
  • 3,037 Answers
Most likely it isn't the defrost timer since you have no frost buildup. I think you are looking at a bad thermostat. The thermostat is the dial that you can set the freezer temperature with. Basically if you set it to it's coldest setting and it doesn't get cold, then it is the easiest thing to replace right away and is the usual cause of failure.
You can order a new one from http://www.repairclinic.com/Appliance-Parts?s=t-GTH22KBRARWW-%3d%3d&z=210
It will be the third part down on that page and is returnable within 30 days along with any other parts you may order now or in the future.
The part is relatively simple to replace for any home handyman. Let me know how this works out.
Benjamin
Posted on Sep 12, 2009
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Sep 12, 2009
    If the part you found looks like the one on this website link http://www.repairclinic.com/SSPartDetail... then you have the right part
  • Benjamin Patri
    Yeah, that should be it since it will be located at the back, The coils are pretty durable and you shouldn't damage them if you unscrew them from the back, the thermostat is held on with a clip and so will just pull out.
  • Benjamin Patri
    yeah, still could be it since these will wear out and cause it to cool just not as much as it should and if it turns out to not be the problem for some reason, then you only bought the cheapest part to replace.
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less...
you may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Aug 22, 2010 | Refrigerators
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
Frost in back of frost free freezer, ice maker not working, frig temp not cold enough
Whats happening is the defrost heater has failed. It is causing ice to build in the freezer and that is stopping ice production and fresh food chilling. Solution: Remove panel to evaporator and replace heater. Use hair dryer to melt ice. I have your repair manual: HERE
An air conditioning heating and ventilation expert named Dr Z normally makes HVAC videos but his neighbor's ice box did the same as yours and he had a chance to check it out and made this short film.He calls it his HVAC Refrigerator repair I thought it was pretty cool, cause it gives a good idea what is involved in this repair. HERE
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GTH22KBRARWW will not keep cold
Very possible that the defrost heater is burned out. Unplug and remove the rear wall in back of the freezer. If frozen over defrost with a hair dryer or let a bucket of hot water sit inside the freezer for a while. After defrost we need to inspect the WR51X10038 or 880036 Defrost Heater to see if it's burned out. If yes the you will need to replace the heater. If we find nothing wrong inside the freezer then we need to have a look at the mother control board. I will help you go through these test if you want, Let me know what you find, Thanks, Sea Breeze
Aug 21, 2009 | GE Refrigerators
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Is there a reset for this brand of GE Profile PSS26MSW
is there a reset for the computer on the back of a ge profile refrigeraton and if so where would it be
May 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PRofile Arctica
Just had mine with the same problem fixed today,it was the main board on the rear of the fridge,common problem with these models told by the tech.
I believe you can get a free board fom ge but you pay labour
Jun 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE side by side refrigerator gss22jfmcww not cooling
they are talking about the motherboard at the back of the unit and are prob right parts people see the promb a lot and was just trying to save you some cash good parts store pull the fridge out you will see a panel at the back on the freezer side pull the cover and inspect and you will see a board look for a burned resistor ge has corrected the problem and the new board cures the problem just follow the inst instructions
Dec 31, 2007 | Refrigerators
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
